Question about bed lining
What is the coldest temperature you can spray on bed lining? I think the can says 58 degrees. I have a front ARB bumper that needs to be sprayed. I wish I had a garage to warm up with space heaters.
Depends on the brand.....what are you using?
can be applied between 32° F and 95° F. However, the colder the temperature and the lower the humidity, the longer the curing process will take. Additionally, it MUST BE APPLIED IN A WELL VENTILATED AREA.
If working in an unheated garage or warehouse space, do not apply if temperature is expected to drop below 50°F. After the coating had been installed, do not expose to temperatures below 50°F for the first 12 hours after application.
60 to 95 degrees, humidity below 70%
