portal-tek Axles
Old 05-07-2008, 03:41 PM
TxCop07's Avatar
Default portal-tek Axles
Does anyone have any information on the portal-tek axles for a JK Jeep? I have emailed them but haven't heard back yet. I am wanting to know how much fabrication is needed to mount the axles, prices for the axles and availability of parts. Here is the website:www.portal-tek.com
Last edited by Robar; 05-07-2008 at 03:42 PM. Reason: Please do not post direct non sponsor links.
Old 05-07-2008, 05:03 PM
TxCop07's Avatar
Bueller...Bueller.....Bueller..... These axles seem to be pretty stout. with all these people going to the solid D60 and the lifts you would think someone would have went this route. As far as i can tell you get the gear reduction and the 4.5 inches of true lift and strong axles. so if you paid about $1200 for a lift, $2000-$3000 per axle, i think you might bebetter off with these.
Old 05-07-2008, 05:21 PM
dugn8r's Avatar
They give you an extra 10" of clearance over the D44. A 9" axle ready to go for the JK starts at $14k for the set. They have CTIS options, too.
Old 05-16-2008, 04:46 AM
Dante's Avatar
Originally Posted by KJRubiconWannaBe
Man, those look REALLY nice.
So, if I'm reading it right, you could put those axles in, gain 4.5" of clearance (equal to lifting 4.5" with a normal suspension lift) AND get stronger axles.
Yep! You could run 37" tires on stock suspension. If you put on a mild spring lift, you could get better flex and run bigger tires. If you were running 40" tires you would still have to deal with the conflict between the size of the tire and wheel well at full stuff. But these axles would handle those big meats just fine.
Old 05-16-2008, 05:28 AM
cyberbrain's Avatar
pretty much the same setup that a hummer uses. the real hummer that is, H1
Old 05-16-2008, 11:49 AM
Offroad's Avatar
If I'm not mistaken, the H1 uses IFS portals.
These would be more like Unimog solid portals.
I'd love to have them, but don't have the money...
Old 05-16-2008, 11:50 AM
tricked919's Avatar
..and UNIMOGS
portals are SICK, but lots of stuff to break. I'd be concerned on a daily driver...
I just saw that I got beat on this /\ ...d@mn... yes the H1 does use IFSP's
Old 05-16-2008, 12:18 PM
they have been around for at least a couple of years, and i have yet to see a set of production axles
atomicmecha's Avatar
whoa... wait a minute... CTIS on a JK? that would be nice to have.
as nice as it would be to upgrade to these axles, most of us just don't have the money. wonder how complicated and hard it would be to put planatary gear sets and rotors on the D44... basicly, turn the stock axles hubs into portal hubs. i get the feeling that it'd still cost about the same, but the D44 would be weaker.
and for anyone that doesn't know what a portal axle is...
Old 05-16-2008, 12:56 PM
pearl-drum-man's Avatar
Do the 2's and 3's not use them, too? Sorry if that's a stupid question. I'm just starting to be semi-literate in JK talk. Haven't begun to learn Hummer talk yet. I'll leave that to the ladies.
No, the H2 and H3 use a traditional GM solid rear axle with an IFS front. A similar setup to current pick-ups.
Quick Reply: portal-tek Axles
