Popping noise
Old 04-24-2012, 01:33 PM
Kedge's Avatar
I had this for about a week, driving me crazy. I finally laid next to the rear tires and the kid put it in gear and move forward. Loose bolt on the control arm located behind the rear tire. Pulled it apart, some locktite, checked the other bolts and no more problem. Been great for about a year now.
Old 04-24-2012, 01:45 PM
rickster's Avatar
The bolt on rear links may be hitting the tire. Check fir a round clean spot in the inside of the tire. This happened to me and soacers solved the problem when i had a 2.5 lift.
Old 04-27-2012, 01:20 PM
bpohio's Avatar
Originally Posted by killerklown24
I am going to ask a somewhat stupid question...did you buy the '08 new? so, you have been driving it for 3-4 years with no major issues?
Yes I did buy it new and No no major issues. I'm not too concerned about it but if someone found the culprit I would like to know.
Old 04-27-2012, 07:31 PM
killerklown24's Avatar
So now more interesting news...just noticed an unusual wear on the edge of my 2 week old 305 Goodyear mt/r's. Had the alignment checked and the pressure lowered to 32 psi. Starting to wonder if all the issues are related...
Old 05-18-2012, 03:51 PM
And the saga continues...popping still happening. I got under there myself and was only able to move one thing, the fuel line from the tank to the cap...by the rear drivers side wheel. I think that may be the issue...
Old 06-05-2012, 07:05 AM
Jeremy072288's Avatar
I have a 3 1/2 inch lift on 35inch toyo m/t's mine makes a noise similar to what your describing. I YouTubed it and I'm pretty sure it's bearings or something in the t-case.
Old 06-05-2012, 11:13 AM
rozzman10's Avatar
Count me in on this one! I have the SAME problem. 4" lift with stock tires.. ya, judge me on that! haha!.. When I back out of a parking space and then take off it makes the same little *pop* FFFUUUUUUUUUUUU
Old 06-06-2012, 04:22 AM
Any word on what the problem is?? Mine is getting so loud now and is happening at every stop and turn I do. I'm going to see if I have time to mess around with it this weekend to try and figure out what's wrong. Is it possible to lube up the ds??????
Old 06-06-2012, 06:08 AM
rozzman10's Avatar
You would think there wouldn't be so many crazy sounds on a vehicle that you can disassemble for every day driving but seriously, what is this noise?!?!?!
Old 06-06-2012, 10:07 AM
patricks99's Avatar
I've had the same "pop" both when stock and after the 2.5 in mopar lift. Almost always occurs when I pull out from the curb, with the top off I still can't tell which side it's coming from but definitely from the rear.
Quick Reply: Popping noise
