Popping noise
I had this for about a week, driving me crazy. I finally laid next to the rear tires and the kid put it in gear and move forward. Loose bolt on the control arm located behind the rear tire. Pulled it apart, some locktite, checked the other bolts and no more problem. Been great for about a year now.
The bolt on rear links may be hitting the tire. Check fir a round clean spot in the inside of the tire. This happened to me and soacers solved the problem when i had a 2.5 lift.
Yes I did buy it new and No no major issues. I'm not too concerned about it but if someone found the culprit I would like to know.
So now more interesting news...just noticed an unusual wear on the edge of my 2 week old 305 Goodyear mt/r's. Had the alignment checked and the pressure lowered to 32 psi. Starting to wonder if all the issues are related...
And the saga continues...popping still happening. I got under there myself and was only able to move one thing, the fuel line from the tank to the cap...by the rear drivers side wheel. I think that may be the issue...
I have a 3 1/2 inch lift on 35inch toyo m/t's mine makes a noise similar to what your describing. I YouTubed it and I'm pretty sure it's bearings or something in the t-case.
Count me in on this one! I have the SAME problem. 4" lift with stock tires.. ya, judge me on that! haha!.. When I back out of a parking space and then take off it makes the same little *pop* FFFUUUUUUUUUUUU
Any word on what the problem is?? Mine is getting so loud now and is happening at every stop and turn I do. I'm going to see if I have time to mess around with it this weekend to try and figure out what's wrong. Is it possible to lube up the ds??????
I've had the same "pop" both when stock and after the 2.5 in mopar lift. Almost always occurs when I pull out from the curb, with the top off I still can't tell which side it's coming from but definitely from the rear.
