Over heated the trans again, should I flush it?
Old 09-29-2011, 09:25 AM
blue project's Avatar
Default Over heated the trans again, should I flush it?
As we all know, that wonderful automatic transmission overheats just by looking at. I didn't get the hot oil light this time, but I could smell it starting to overheat for the 2nd time. Should I get it flushed? I'm think that the fluid has got to be cooked by now.
Old 09-29-2011, 09:48 AM
Steelgrave's Avatar
How many miles are on the fluid in it now?
Old 09-29-2011, 09:52 AM
Rob 12B1P's Avatar
I would try and get a whiff of it after it is cooled to see if it smells burnt.
Old 09-29-2011, 09:57 AM
10,500 or there about. I concerned about the quality after getting so hot a few times.
Old 09-29-2011, 10:04 AM
jsears's Avatar
I'd flush it just to be on the safe side. It's cheap insurance compared to a transmission rebuild. Trust me, I just had to have mine rebuilt.
Look into the ORW Transmission Cooler. Even more cheap insurance.
Old 09-29-2011, 10:21 AM
Freewill's Avatar
What are the conditions when the transmission overheats?
Ambient temp?
Off road or on road?
Tire size?
Climbing a lot or running level?
How heavy is your Jeep? (JK/JKU, extra weight like bumpers, winch, armor)
Anyone?
Subscribed
Old 09-29-2011, 11:00 AM
jsears's Avatar
Ambient temp?
Tire size?
Anyone?
Subscribed
All of those are factors that contribute to getting the "HOT OIL" notification/warning on your Jeep.
The most common factor I have read/seen causing the warning is doing a lot of wheeling in 4-hi. I know a guy that has gotten the "HOT OIL" message in his stock JKU just running up a forest service road in 4-hi.
Old 09-29-2011, 11:08 AM
greenenvey's Avatar
I know other have said it already, but put a tranny cooler on it! They are only 60$ and then you don't have to worry about it anymore, if it were me I would put fresh fluid i'n it if I was even a little concerned it got to hot
Old 09-29-2011, 11:14 AM
jsears's Avatar
I agree! My tranny rebuild was in the neighborhood of $2,500.....
Old 09-29-2011, 01:55 PM
Ambient temp?
Tire size?
Anyone?
Subscribed
Both times I was driving on the beach. First time was my bad because I was in 4-hi and didnt air down the tires. The rpms where running high because I was trying to be a speed demon on sand. The 2nd time I aired down and was in 4-lo just like I have a thousand times before. That seemed to work until the other night. I was again trying to drive like I stole it in 4-lo but the rpms didnt go much past 2-2.5 and that was only for 20-30 seconds then I went back to normal driving across the sand. Tires are 32", I have a superchips tune with a cold air intake. I even changed the tune so the fan will turn on at a lwer temp but the temp gauge always reads tiny bit under half. My jeep is a 2010 2dr, TF Coil leveling kit w/ bilstein shocks. Stock bumpers and such. Not really that heavy.
Quick Reply: Over heated the trans again, should I flush it?
