Oil consumption "fix"
#21
So are they claiming the compression test messed the the plug wire or the guy that pulled the wire messed it up?
Anyway, have them perform a leak down test also (you might get a new set of wires if they keep up what they're doing ) and see what the loss percentage is and where the leak is coming from.
#22
#23
Shows what I know. Anyway, I would try one of the other 5 if they still can't get it figured out after the tear down, it sure wouldn't hurt at this point. I would be worried about that bunch tearing my engine down to be honest with you. I hope someone gets it figured out for you.
Put the spark plugs in wrong?,..........really? Wow.
#24
#26
Originally Posted by jeepmojo
i hate taking the jeep in for anything ! the less you go to the dealers the better off youl be ! id rather feed it oil than be going back and forth with a lost cause
definitely never buying another chrysler after reading everyones troubles and having my own problems , my wish was that i bought somthing else i think like a pick up ! these things seem like one trouble after another ! wonder why so many are loyal to the jeep when every one seems to be having problems !
#28
Originally Posted by 07jeeper
Sounds like you are going to be out of your jeep for a while. That sucks, I hope they fix it. Good luck
#29
Thanks! They need it tomoro afternoon so it can have enough time to sit. Then first thing Tuesday morning they will rip the engine out. Then tear it apart. Then they will call the adjustor from Zurich an have him come look (takes 2 days) then assuming he approves the claim. They will order the parts they need (takes 3 days) then they will install the new parts or new motor. Then they will have it back to me
#30
They only work thru a Chrysler dealer. I tried. I inured putting silicone in there would be bad. But it's Montana. They don't care. I've been here 4+ hrs now. Letting them fix what they screwed. They claim that when they did the compression test it messed up a spark plug wire. So now they are replacing that wire. Then I should be good. If it is still messed up ten I'll show them your post. Thanks for this post by the way. It will be good to have him read
