Oil consumption "fix"
Then the sucky thing about lemon laws....I bought the vehicle in salt lake city. I live in Montana. Montana lemon law says it covers any vehicle purchased in Montana.
Location: Missoula, Montana. but currently JBER, Alaska
holy crap!!!! I gotta a 2010 with about 4400 miles on it, I am going to check my oil right now!!! hey....how do you find out what warrenty you have...I cant remember what I purchased????
Even if you have an aftermarket, it is only above and beyond the factory warranty. Make sure that you are not paying for "warranty time" while the factory warranty is still valid.
Originally Posted by Bucko
Well at least you have friends in high places! Looks like you'll have to go through the paces. At any rate, good luck.
They put silicone around the PCV valve? I'm sure it sucked in some sealant and that is why you are having issues with driveability. If the PCV valve did not fix your oil in the intake problem, you have too much blow by in the engine. That dealership suXx nuts and I suggest you take it somewhere else (after they fix what they screwed up in your PCV system). BTW, placing silicone around the PCV valve could be considered an illegal modification of the emissions system and if you are in California, would fail an emissions test with an attentive SMOG tech.
You should be able to take your vehicle to a reputable ma and pa shop since you have a non-chrysler warranty.
I think I read somewhere in this forum several months ago that they had the same problem with oil consumption and after the dealer tore down the engine they found the piston rings had been installed backwards or incorrectly.
That has been found in some cases. Also, connecting rods have been found installed backwards, preventing the major thrust side of the cylinder from getting adequate lubrication.
