New lift now traction control probs.
Nothing unusual. Very slight pull to the left and steering wheel slightly off center. Pull was a tire balance issue and I could have corrected the wheel myself but I have always had a computerized alignment done after changing suspension or steering components. Tires cost too much to chew thru them for no reason.
The AEV is a great kit and should have come with everything you need.
What size tires are you running?
What wheels are you running? I understand if the wheels have extreme negative offset you might run into issues with ESP.
Originally Posted by Strombeck
How would you know if the axels are centered?
Originally Posted by rdubb1031
I"m still having this issue.. only 2.5" lift now 3.5". aligned many times, center wheel many times, added adj trackbar back in feb. still happening..
Rdubb1031 & Strombeck, I don't see adjustable front control arms in your signature. I had the same issues on my 2008. I have found the best fix is to add adjustable lower front control arms. The new arms will allow you to get your caster properly set.
Hmmm.. I guess I'll look in to this. I"m going to get some AEV drop brackets next week, install those and see what happens. after that I'll look for from front LCAs. you wouldn't happen to remember what dimension you set them at over stock?
Set your lcas to 23" to start, and fine tune from there. The 23" starting point is about 3/8" longer than stock. The 3/8's longer sound like just a little, bit it makes a big difference.
I had mine set to 23 1/8 which equaled no more esp issues.
