New Jeep Truck: Wave or Not to Wave
Old 09-30-2010, 02:52 AM
  #31
MaineRubi's Avatar
Originally Posted by Mariner
of course you should wave, you wave to four doors don't you?
HEY! I resemble that remark!!
The wave has been around a lot longer than the Wranglers. Us former CJ owners used to do it way back when. I do find a lot of "kids" in TJ's and JK's don't wave. I have yet to see a CJ or YJ driver not wave back.
If it looks like a JK with a truck bed, I will wave, just like seeing a CJ-8 (Scrambler).
Old 09-30-2010, 02:58 AM
  #32
jkdave713's Avatar
Originally Posted by Harbourone
Wow you guys need some friends or something. Who cares who waves to who?
x-2 WGABF ANYWAY
Old 09-30-2010, 04:19 AM
  #33
swampman's Avatar
this was posted some where long before wranglers were around
Jeep wave rules
Warning
Owning, registering, insuring, or driving a Jeep implies knowledge of and intent to abide by the following rules. Failure to obey the rules may result in your being ignored by other Jeep owners as you sit along the side of the road next to your stalled vehicle in a blizzard surrounded by Saturns, Yugos, and Hyundais.
Definition of the Jeep wave: An honor bestowed upon those drivers with superior intelligence, taste, class, and discompfort tolerance to own the ultimate vehicle- the JEEP. Generally consists of vigourous side to side motion of one or both hands, but may be modified to suit circumstances and locally accepted etiqeutte.
Examples of commonly accepted modifications:
Top off: One handed wave above windshield or outside body tub .
Top off during blizzard: Shiver and nod, hands may remain frozen to steering wheel .
Southern/rural locations: Raise fingers from steering wheel, nod.
It's not what you buy, it's what you build and what you do with it.
In keeping with this cardinal rule of Jeeping, categories have been established to account for each part of the equation.
These categories are:
The Jeep Waving Hierarchy: Based on the vehicle itself. Takes into account the nastalgia factor, the discomfort tolerance quotient, and the amount of owner dedication required to maintain the steed.
The Moifying Sub-categories: Based on what you do with your JEEP.
Equipmant Adjustments: What you build.
General Rules
1. All Jeepers are responsible for upholding the tradition of the Wave. Upon contact with a higher scoring Jeep, a Jeeper is
required to initiate the Wave, and continue the Wave until:
a. The Wave is returned
b. The Wave is blatantly disregarded
c. The higher scoring vehicle has passed by and is out of sight
2. All Jeepers are required to return the Wave, unless the initiating vehicle clearly has a negative (below 0) score.
3. All Jeepers are encouraged, but not required, to return the Wave to negative balance vehicles, and take any opportunity presented to guide and mentor them about their responsibilities to their Jeeps in the hopes that they can correct the error of their ways.
4. When unsure of status or wave requirements of a particular encounter, or unable to completely assess the other Jeep's score quickly enough to ensure that the proper Jeep Wave Etiquette rules are followed, immediately initiate wave. It is the spirit of waving that is most important so when in doubt: Just Wave!
The Jeep Waving Hierarchy (JWH)
Category A - Pre-CJ (Willys/Kaiser/MB/etc): 30
Category B - Pre-AMC CJ: 27
Category C - CJ: 25
Category D - Commando: 20
Category E - YJ: 16
Category F - TJ: 15
Category G - Cherokee, Wagoneer: 10
Category H - All other Jeeps: 5
Category I - All other 4WD vehicles EXCEPT yuppie Explorers: 0
Category J - All other vehicles: -5
The Modifying Sub-Categories (MSCs):
MSC Guidelines:
1. MSCs must be considered during all Jeep encounters, and wave patterns must be adjusted accordingly.
2. MSC 5 is the median - the accepted norm.
3. MSCs from 1 through 4 will increase score as listed.
4. MSCs 6 and 7 will decrease score as listed.
MSC 1: Top off; vehicle, driver, and all occupants covered with mud: +30
MSC 2: Top partially off; vehicle and some occupants covered with Mud: +20
MSC 3: Top on; vehicle covered with mud: +10
MSC 4: Top off during snow, sleet, hail, or heavy rain: +5
MSC 5: Somewhat dirty: 0
MSC 6: Obviously recently washed, but immediately re-muddied a little: -10
MSC 7: Clean, dry, unscratched, untested: -30
Equipment Adjustments (EAs)
Consideration must be given to the current mechanical condition of the vehicle, including all modifications for trailworthiness, comfort, appearance, and spouse-appeasal. These are known as Equipment Adjustments (EAs). EAs are only granted after the work has been completed. We all have plans for EAs, but only the ones actually implemented can be scored.
EAs are a complicated category, and often difficult to appraise under certain conditions (passing head-to-head at 60 mph, when covered with mud, etc) but must be used to modify score when feasible. If a vehicle is so covered with mud that you are unable to ascertain any of the EAs, you MUST assume that the EAs, when combined with the MSC 1 adjustment, would place the vehicle in a higher scoring position than any non-MSC 1 Jeep, and immediately initiate the wave. Otherwise, EAs will adjust score as follows:
Engine:
Stock, Pre-CJ, Working Condition: +2
Stock, 8-cyl: +2
Stock, 6-cyl: +1
Stock, 4-cyl: 0
Replaced, 8-cyl: +3
Replaced, 6-cyl (replacing 4-cyl): +2
Replaced, 6-cyl (replacing 6-cyl): 0
Replaced, 6-cyl (replacing 8-cyl): -1
Replaced, 4-cyl: -1
Drivetrain Modifications:
Improved internal mechanical parts (crank/cam/etc): +2 each
Upgraded Transmission: NV4500 or Turbo400: +3, All others: +2
Upgraded Transfer Case: +2
Improved exterior mechanical parts (headers/manifolds/pumps/filters/etc): +1 each
Stone stock in a pre-1970 vehicle: +3 (for nostalgia and historical analysis)
All Comfort enhancements removed for more power: +2
Tires:
Stock or unremarkable: 0
Original Tires on Pre-CJ: +2
Slightly oversized (up to 31"): +1
Over 31, with other appropriate mods: +2
Any size, currently covered with mud: +2
Working tires > 31" with original donut spare: -2
Low-profile: -10
Suspension:
Stock, Pre-CJ: +2 if driver can still walk after an hour in the saddle
Body lift: +1/inch
Suspension lift: +2/inch
Spring-Over Lift: +3
High-quality shocks: +2
Lowered: -20
Other accessories/conditions:
Winch, heavy-duty, obviously used: +2
Winch, heavy-duty, use unclear: +1
Other winch, obviously used: +1
Little, chrome-covered, toy winch: -1
Lockers: +2
Upgraded axles: +1
Upgraded transfer case: +1
Each chrome accessory currently shiny: -1
Each neon accessory: -2
Fire extinguishers: +1
Block and Tackle, anchors, etc: +2
Ropes, straps, tow chains: +1
Tow Hooks: +1
Nerf Bars/Rock Rails, used and scarred: +2
Nerf Bars, shiny, no scars: -1
Heavy duty bash/skid plates: +1
Other protective plating (diamond plate, etc): +2 if scarred, -2 if unscarred
Extra fuel tanks/oversize fuel tanks: +1
External Gear Carrying Rack: +1
Multi disc-CD Player: -1
More than one subwoofer: -1 each
First Aid Kit: +1
Backpack, food, emergency gear (just in case): +2
On-board air compressor: +1
On-board Welder: +2
Girly, shiny chrome center caps: -1
Krylon home-made paint job: +1 (for realizing it's just going to happen again)
Blackout Headlight Covers: -1
Any little flippy interior vanity mirrors: -1
Children in vehicle: +1/each (for proper training/indoctrination), +2 if muddy, an immediate correction if not belted in.
EARNED trip stickers/badges/etc: +1/each
Unearned stickers/badges/etc: -2/each
Stickers advertising for other than 4wd-related businesses: -2 (except No Fear: -5)
MSC 1 vehicle in corporate lot sharing with neighbor vehicles: +1 per vehicle decorated
Correct mental attitude, seen or proven: +3
Windshield down: +1 (+2 if raining/snowing)
Bugs left on face/teeth as evidence of recent windshield down driving: +1 (+2 if more than a week old)
CB radio or other communication tool (for emergency only): +1
Hi-Lift Jack: +2
Flexible caulking to fill leaks and body damage: +2
Dogs as passengers, properly secured: +1 (sharing the joy of Jeeping)
Bringing a new Jeeper into the Family: +5
Extra Lighting, used for night-wheeling, not pastel or neon colored: +1/ea
Battle Scars:
Mashed hood, top, etc., obviously from roll-over: +3
Holes above glove box where passenger ripped grab-bar out: +3
Heavily gouged rocker panels: +2
Bloody seats: +2
V-bent front bumper from being pulled out of that REALLY bad one: +2
Scarred sides from those mis-judged rocks: +1
Any small parking lot dent/scratch still identifiable: -1
Other accessories bent, folded, mangled or mutilated: +1, EXCEPT:
See above, but said item is owned by your spouse: +2
No scars whatsoever: -3 (Unless Pre-CJ restored, then: +3)
New body due to rust only: -5 (unless a rescue, see discussion below)
New body due to damage: Previous damage points carry over (see discussion below)
Fire Damage (bubbled paint, singed seats, etc): +2
Limbs, Shrubs, etc attached well enough to remain at highway speed: +1/each
Old 09-30-2010, 04:25 AM
  #34
swampman's Avatar
i suppose its time to update the list to include wranglers, and might explain why most jk ownwers dont wave ,
Old 09-30-2010, 05:41 AM
  #35
MN10JKMountain's Avatar
I would wave. Like the other on this post have said, "it's a JK with a bed"
Old 09-30-2010, 07:35 AM
  #36
08RedRecon's Avatar
I wave no matter what. I may be broke down someday and one of those guys might pass me and say hey, there is that nice guy Ive seen wave at me before,let me pull over and see if he needs any help.
Old 03-01-2011, 08:04 PM
  #37
jcopel's Avatar
Thumbs up
Hey, this sounds like the motorcycle forum.
I ride a bike. I wave to other bikes. I just got a jeep, and I wave to other jeeps. Problem is, when I'm in the old Durango, I wave at both. Get some strange looks back.
It's all good.
I'll wave to trucks.
Old 03-01-2011, 08:15 PM
  #38
Former Member
dwhitt74's Avatar
Originally Posted by db99wj
I'll wave, I wave at moded Grand's and Cherokee's as well.
And remember, TJ's killed the Jeep wave!
Me too! There is a pretty healthy population of modded grand's in Cheyenne and they are pretty friendly to wranglers... pretty cool
Old 03-01-2011, 08:16 PM
  #39
ckatz88's Avatar
Id wave. Jeeps aren't the group with a wave. There's the motorcycle wave, boat wave, and lifted super duty wave.
Old 03-01-2011, 08:22 PM
  #40
Abacabb's Avatar
I'll wave at anything that's lifted/looks awesome. I don't give a shit who makes it.
Quick Reply: New Jeep Truck: Wave or Not to Wave
