The most unanswered question in JK history. Let’s solve it on this Forum!
You are close enough to a major city that you can probably find a "mod friendly" dealership (maybe try the local forum)... if you lift your jeep for bigger tires there is no way they can void your warranty for an AC or an electrial issue (if they do find another dealership, but don't piss them off). Obviously they are less likely to warranty your driveshaft or axles with lift and bigger tires, but its not like these things fail all the time.
I was in your same situation when I bought my Jeep where I wanted bigger tires but I was worried about the warranty... I thought about running 33's with no lift... but I knew I wouldn't be happy with that and went to 35's.
Just go all in... you know you want get a lift, throw caution to the wind!
If your worried about jeep flagging you and you want a lift and tires go this route.
Get the rubicon take off wheels and tires and find 19/60 springs/shocks from a member or buy new from jeep.
That way everything is factory from jeep and they can say its from aftermarket parts causing wear on items. You will be very surprised where a stock jeep can go. Once you get the springs and wheels save up for bumpers, winch, recovery gear,lighting, rock rails and the list goes on.
All bought from forum members slightly used.
Best of all it coast me $1175.00 total and I installed with the help of a buddy
Before
After
Next to stock Sport just like mine originally
Next to stock Rubicon
Next to stock Sahara
Love the look and stance. Ride is much better IMO. I know I can install larger tires on down the road too.
You couldn't be more incorrect. Even if all you did was lift a Prius, Fiesta, Civic, etc, it would drop their mileage considerably too. When you lift things you expose components that now become part of the entire picture of what will cause more aerodynamic drag for your vehicle. It is no different than if you take an extremely aerodynamic car and place a roof rack, big flat Offroad lights, anything that will upset a smooth air flow now becomes a wind brake.
This thread is one of HUNDREDS identical to others on this forum, no need to regurgitate those threads here all over again.
Subscribed - I also have a lifted Jeep on 35's but I want to see how this works out.
33s no lift
Attachment 382783
33s with 2.5in lift
Attachment 382784
35s with 2.5in lift
Attachment 382785
35s with 4in lift - Mine
Attachment 382786
33s no lift
Attachment 382783
33s with 2.5in lift
Attachment 382784
35s with 2.5in lift
Attachment 382785
Attachment 382786
I had 4.5" backspacing with 33" equivalent tires and still rubbed offroad. My gas mileage dropped by about 1 mile per gallon, in part due to removing my plastic front air dam, and lifting your jeep doesn't automatically void your warranty.
When I spoke to my dealer about a lift and the warranty he told me it would only void the warranty on areas that were replaced with aftermarket. So basically I just voided the warranty on my suspension and nothing else but not a big deal because if I damage something there I would rather replace it myself with aftermarket anyway and not OEM. I have been back a few times for small things like emergency brake making a loud pop noise ( if anyone knows the issue there please let me know because they couldn't find anything wrong) and other minor electrical stuff and had no issues. I'm sure all dealers are different and this may not apply everywhere.
Thank you for your respsonse, how about on the road any problems. And when you say they rub off road how bad is it, are you offroading on some mild terrain when it happens or are you talking climbing rocks?
