Mopar Sun Bonnet Owners
I bought the softop a year after buying the hardtop version of the Sunbonnet--so replaced the Sunbonnet with the softtop version to get the weather tightness benefits (it's still open in the back on the four doors).
One of many threads: Best Safari Top
The hardtop version attaches with large Velcro panels around the roll bar above the driver and passenger. The softtop version attaches with the door frames. The latter provides a more weather tight seal.
The 2 part #'s you put up there one is like !&) bucks and is on back order and the other is like 275 or so and it is available, are the part #'s you have are they correct or from like quadratec ? Where did you get the part #'s from so I can see maybe there is some sort of explanation of the 2 ?
I have done some further investigating and the part #'s are from mopar and are for the unlimited not the 2 dr. The 2 door part #'s are
Soft Top - 82209927 $238.00
Hard Top- 82209928 $254.00
I don't know if I was quick to jump at the info being incorrct if it wasn't intended for me.
Experienced Similar Issue with Sun Bonnet
POTO,
Did you ever get your issue resolved? I did the samething you did. I ordered the Sun Bonnet with the Mopar bucks and it did not have the header bar either. I did the same research you did and went back to the dealer and showed them the pictures from this post and the exchanged it for the correct one.
Best of Luck on dealing the Mopar.
So, does this Mopar one require the plastic door frames to be installed? I got the bestop one when it first came out and it sucks (at least without the frames). It needs to be retightened every time you drive it.
