Mopar Dana 60 is on the Way!!
Old 09-17-2008, 01:24 PM
  #41
Mopar part: #p5155083
dana 60 LP
From what I hear its NOT an e-locked axle and is set up for leaf springs.
I have been waiting for this to come out for some time. I was hoping it would be a cheaper price point.
now my 60 rear end options are:
Mopar LP dana 60: $2425
JK bracket kit: $400
Dana 60 LP gears + install: $400
total: $3225 not assembled
OR
Rock Jock HP 60: $1900
ARB + gears and install: $1600
total: $3500 assembled
This is comparing a LP to a HP and mystery locker to an ARB. We also don't know the housing tube size of the Mopar part or the thickness. Rock Jock has 3" tubes with 1/4" thickness. Rock Jock has a skid with 5/16th diff cover. Mopar has no skid with ??? thick diff cover.
EDIT: Ohh I forgot to mention that Rock Jock uses your factory brake bracket calipers and rotors but is drilled for 5on5 or 5on5&1/2 Mopar is just 5on5&1/2 but come with brakes that will accept factory calipers.
MY choices are starting to become clear!
Old 09-20-2008, 06:32 AM
  #42
PONCH's Avatar
Do we have any hard facts yet?
Old 09-20-2008, 06:40 AM
  #43
PONCH's Avatar
nevermind...found the info
Old 09-20-2008, 05:36 PM
  #44
Frog Rubicon's Avatar
Honestly, I'm very satisfied with my Dana 44.
Dana 44 = Gas $$$
Dana 60 = Gas $$$$$$$$$
Old 09-20-2008, 07:28 PM
  #45
TBJK's Avatar
Originally Posted by HITMONEY
Is this set up for leaf springs?? I know someone that has one for sale still in the crate, Dana 60 4.10's complete for JK.. but it is set up for leaf spring jk (military/diesel).
Ahhh thats what they make torches and welding machines for mod it
Old 09-22-2008, 10:20 AM
  #46
Vega's Avatar
Dana 44 = Gas $$$
Are you saying that with a Dana 60 having more drivetrain power loss your Miles per gallon will decrease or do you mean you will have less money for gas if you purchased a Dana 60?
Old 09-27-2008, 05:54 AM
  #47
Tony23's Avatar
Quadratec has it on their site.
http://www.quadratec.com/products/52446_103_T.htm
Old 09-27-2008, 07:03 AM
  #48
PONCH's Avatar
I thought this thing was suppose to have leaf springs? Looks like this changes things a bit.
Old 09-27-2008, 07:31 AM
  #49
PONCH's Avatar
Originally Posted by benmar2000
From what I got from my dealership, it is a direct replacement to the D44 in the rear of the JK.. You could cut off the mounts for the coil springs and weld on some leaf spring pads and do a rear leaf spring conversion..
That sounds good, I didn't want leafs in the rear. Rumor had it, it was made for leaf springs. Good find!
Old 09-27-2008, 08:35 AM
  #50
Littlejon's Avatar
Can anyone confirm the bolt pattern on this? I would assume they ended up going 5x5 since it is advertised as a plug and play swap, but just wanted to make sure.
Quick Reply: Mopar Dana 60 is on the Way!!
