lost wheel lock key
lost wheel lock key
Ok fellow Jeepers, lets pretend that I lost my wheel lock key..... what could I do to get the wheel locks off with out a key? has anyone ever done this? thanks for the help
Mine are Gorilla locking lugs.....they came with a little sticker that has a code on it so you can call the company and get a new key if necessary. If you don't have that info...
any tire shop will be able to do this for you, or you can go buy a tool call an "easy off." I would just let the tire shop do it though...but you will need to buy new wheel locks...
I worked at a Sears tire shop during high school. We had to remove keyed lug nuts on a weekly basis. We just hammered a tight fitting socket over the lug nut and it was enough to get the nut off.
Remove before going offroad
From what I have seen before you go offroad I would replace them with regular lugnuts. If you lose the key you can get a replacement as long as you have the number that came with the ones you bought. If you can't get a new key you will have to weld a nut onto the head to get it off.
Good to have on in high crime areas but not so good in the boondocks.
things to try out
thanks for the tips, i went to 2 different dealerships and tried more than 20 different keys that they had in a bucket and non worked... i think ill take it to a wheel shop
thanks again for the help and people say that smoking is addicting but i think im on this site more than i ever smoked in a day lol so much help and good info
