Legality of Beadlocks?
#21
I am out here in KY and i see them everywhere and for the most part if you get pulled over whos really going to know if they are real or if they are look alikes?
#22
The problem with the beadlock ring coming off has nothing to do with
damaging another vehicle. A true beadlock retains the outer bead of the tire to the wheel, so if the ring comes off, so does the outer bead of the tire
. With nothing retaining the tire to the wheel, it obviously goes flat instantaneously and you crash. That's why they are illegal. I am a Rhode Island state inspector, and they are very clear that it is illegal here.
#23
Assuming that you read the excerpt before/after posting the link, you read that this isn't a state matter. The SAE is applicable across state lines. Inherently, the assumption from both of our posts is that each state abides by the SAE and, thus, finds beadlocks to be illegal.
Furthering the point and the conversation... beadlocks are for off-road use, they aren't explicitly legal in any state. Could a state have potential loopholes, sure, but I don't think that changes the intent of the law. Now, if you wanted to argue the point... your direction could be towards whether the manufacturer clearly and distinctively stated that the product is for off-road use only. Save for that, you are left to the legal verbiage in each state. If the product is marketed as off-road use only, you don't have an argument against the state for telling you that the wheels are illegal. See the sick cycle here?
Properly installed and routinely checked, it's absolutely possible to run beadlocks on the road and never get caught. If you do so, you have to accept the associated consequences (which include being busted by the authorities). I will be running beadlocks for on-road use and off-road use. I have accepted the inherent and related consequences.
#25
Did not mean to be argumentative, just informative...
I would still like to read something from states where some posters have indicated that they were indeed illegal.
#27
I already know that there is nothing in the Texas law that states that they are illegal, but it would be beneficial to see if there is something obscure that some states use to indicate that they are unlawful in some way.
That information could be used by users in other states to investigate further.
#28
I run beadlocks on my daily driver and at 24 bolts per ring I'm not the slightest bit concerned about that ring coming off, ever.
Also it's true that the ring holds the bead but there is a small bead on the wheel - i.e. the ring can be removed without the tire going POOF flat. I can't imagine it's any different on other beadlocks or wouldn't they be damn near impossible to mount as I'm quite certain the beadlock ring alone isn't an airtight seal? And with the ring off I'd have to hit a decent pothole on the highway to blow the bead (of-course it'd be stupid to ever run the wheel without the ring). The ring is there to hold the bead particularly in low pressure use and pinch conditions (crawling) where it would be prone to pop off the bead.
So anyways based on what that link says I think it could be interpretted as "beadlocks are legal" as long as the beadlock ring isn't the only thing holding the tire to the wheel - i.e. as long as the tire stays on the wheel with the ring off under normal conditions.
Of-course it'll always depend on the mood of whomever pulls you over!
#29
I simply asked previously that if people think or know that it is illegal in their state, to provide something to the other users so that they may look for similar language in the laws of their states.
If you go through life only heeding the black and white legality of the law, you're opening yourself up to a world of hurt. The premise of my post was to educate those questioning legality. Please keep in mind that I did state above my intent to run beadlocks on the street. I accept whatever comes my way. Think of it as going without a front license plate... if you live in a state that requires a front plate and you decide to go without, you accepted the risk. If you put that plate in your front window (instead of on the front bumper) and get a similar ticket, again... you have accepted the risk of not attaching the plate where it is supposed to be.
#30
In my opinion - As to the manufacturer's always putting "for off-road use only" and/or "not for highway use" is largely due to the cost associated with paying off whatever gov't agency (MILLIONS) to be allowed to put a "DOT Approved" sticker on it. That's simply not feasible for a product with a limited and specific market (off roaders).
