Largest tires on stock suspension?
Old 12-23-2009, 06:18 PM
JayhawkJeep's Avatar
If I re-call the Lower 40 was heavily modified. If had to even modify the windshield. I am all about lot center of gravity I don't think it is worth the cost.
Old 12-23-2009, 06:19 PM
Jusaplaya's Avatar
Originally Posted by spinlock
On a 4dr there are ~30" clearance lengthwise on the rear and ~37" on the front. The two door can't be too much different, but not too worry because the wheel well is plastic so it can easily be pushed out of the way by the repeated impact of a ~150 Lb Baja Clawsl.
I had that happen with my 33's. All it does it melt the plastic on the bottom of the fenders. If you got flat fenders you probably could stuff 35's. It probably look cool. Chop the sides off the front bumper, unless you want the 35's to take them off for you.
Quick Reply: Largest tires on stock suspension?
