JK unlimited towing ?
Old 01-08-2011 | 07:04 PM
envied4x4's Avatar
Default JK unlimited towing ?
I am looking at getting a new JK unlimited and selling my 09 Tundra so the question is can the JK tow a 16" flat trailer with a 350z on it safely?
Thanks
Old 01-08-2011 | 07:22 PM
Se2002's Avatar
Your Tundra is going to tow that trailer better than a JKU. But as I've mentioned before, I've towed our 18' SeaRay; it takes time to get up to speed.
How often and far are you towing the 350?
Old 01-08-2011 | 07:28 PM
envied4x4's Avatar
Hey, Yeah i know the Tundra does way better than a JK but i dont really drive it. I dont tow all that much at all. I would tow from here in Vegas to Phoenix at the furthest.
The JK would be lifted with 35'' tires.
Old 01-08-2011 | 07:38 PM
Runewolf1973's Avatar
I don't think you'ld have much problem towing a 16" trailer. Might be a little tight on space though. Just kidding.
Old 01-08-2011 | 07:57 PM
FAMILY-CRAWL's Avatar
Yea you would be fine pulling that
Old 01-08-2011 | 08:00 PM
NDN_GREEN's Avatar
Don't go over 4000 pounds , sure it will pull anything , but the fram isn't made for it at all best to stay at 3500 or less
Old 01-08-2011 | 08:06 PM
With that 3500, should you also include the weight of the passengers, cargo, oversized tires, 200lb aftermarket bumpers etc...? So after all that extra weight, how much towing capability is there still left?
Old 01-09-2011 | 05:40 AM
Jim M's Avatar
I tow about 3300# with my JK. The Jeep is basically stock, a Rubi 4DR auto. I've added a trans cooler and never had the "hot oil" warning.
The experience has been quite unsatisfying. Forget overdrive (manual says to turn it off anyway), forget passing, and forget double digit fuel economy. It is downright slow. The engine struggles mightily on any sort of hill and the trans shifts often. The engine revs are quite high, but I have had no issues after 24K miles.
Despite the engine's shortcomings, the chassis has been pretty stable. My boat trailer has brakes, which are properly adjusted and functioning, so I've never felt like the JK was being pushed. I've been towing for 22 years so I keep it slow into turns and ramps and have never felt in danger in those situations.
To keep within the factory specs I usually don't carry any other people or gear in the Jeep. Many people don't care about being over weight, but the way my luck goes I'll be involved in an accident and some young attorney will have everything put on a truck scale to make a name for themselves in some lawsuit.
If you were closer I'd hook up the boat and let you feel how it performs. If you go with 35's you will have to carefully consider your gears.
Old 01-09-2011 | 09:29 AM
Phantasm's Avatar
Vet Army
Those 35s are going to hurt you on towing power and make the engine work harder which could lead to an overheat condition especially in the southwest in the summer.
Old 01-09-2011 | 06:52 PM
kiwi's Avatar
Originally Posted by HHaase
I doubt that frame strength is an issue at all, the 3500lb limitation is mainly based on the (lack of) available power. After all, the CRD Wranglers in the UK are rated at 3500kg's towing capacity, which works out to around 7700lbs.
-Hans
CRD 4 door is only 2300kg
