jk trouble
Old 07-20-2010 | 07:39 AM
  #21
TheKid25's Avatar
Originally Posted by RockyBlue
I have an 07 as well and just had to replace my battery. Almost have 50k miles on it though so I'm sure that had something to do with it. Do you have an autozone or something comparable nearby? Take it to them and they will test your battery and charing system for free. When my battery started to go I had a couple of hard starts and mysteriously my radio clock was resetting....
I have an '07 as well and just turned 50K. I had to replace my battery about 2 weeks ago, but my battery kept dying and would crank. Took it as an opportunity to buy an Optima. Did you check out your fuses? It would be worth swapping it out even if it looks good. Worth trying to rule it out.
Old 07-21-2010 | 09:47 AM
  #22
LaxAHolic's Avatar
my fuses were good, checked them all. my jeep is home in the garage, so i cant get it fixed til i go back home..
Old 07-22-2010 | 10:29 PM
  #23
ElyasWolff's Avatar
Check your thermostat.
Old 07-23-2010 | 02:47 AM
  #24
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
Originally Posted by LaxAHolic
... i took the jeep all 3 hours home last night. ran just fine in the cool evening hours, but it did heat back up sitting at stop lights
Yep, sounds like the fan, or the power to the fan.
Old 07-23-2010 | 04:08 AM
  #25
Kauaian's Avatar
x2
fine on the move, overheating on stops...
there should be a fan relay, or control module
whenever i need a wiring diagram i purchased a service manual from that "auction site" seems people get replicas of the actual dealership service manuals..its been a ton of help for me in the past...reminds me i still need to get one for me
hopefully someone out there already had one they can scan for everyone to look at?
Old 07-23-2010 | 05:53 AM
  #26
Originally Posted by Kauaian
... whenever i need a wiring diagram i purchased a service manual from that "auction site" ... hopefully someone out there already had one they can scan for everyone to look at?
I have a digital version and did try looking up how the fan control circuit works. That manual ('07) is sadly lacking. Could not find anything beyond a vague reference to a two-speed control. Nothing in the parts breakdown that I could find; nothing in wiring diagrams; nothing in the maintenance procedures. I think having hardcopies makes it a bit easier to find some of this stuff, but being more familiar with these books than me would help a lot. I hope someone pipes up with some more detailed info about how the fan is controlled, because the problem may be in that control circuitry.
Old 07-23-2010 | 08:25 AM
  #27
LaxAHolic's Avatar
i talked to a friend who is a mechanic, and he said without looking at it, he thinks its the relay to the fan. hes going to help me look at it tmrw so i can fix it myself next time.
Old 07-25-2010 | 08:22 PM
  #28
LaxAHolic's Avatar
thought id update u guys, it was the fan motor..ill have the part wednesday and im good to go.
thanks for everyones input!
Old 07-27-2010 | 07:48 PM
  #29
Dylanjam77's Avatar
Congrats on a fairly quick diagnose and fix. Glad to hear your rig will be back to normal in no time.
Old 07-27-2010 | 09:54 PM
  #30
pastorsteve's Avatar
Well our jeeps have one electric fan. If you go out to your driveway, start the car and run the airconditioning the fan should kick in almost immediately (should run to cool the condensor). If it doesn't turn on then check the wiring to the fan.
Now that he's getting repaired and will be fine...........Rocky........it's not a car. Repeat after me....Jeep......Jeep.......Jeep....start the Jeep.
