Jeep wont run!!! Help!!!
Old 07-12-2009, 07:18 PM
benny's Avatar
When you take the plugs out see if it will crank and possibly push any water out of your cylinders.
Old 07-12-2009, 07:19 PM
mkjeep's Avatar
Originally Posted by LaxAHolic
do u honestly think swapping out the plugs wont do anyting?
Not if there's water in the airbox, you could pull all the plugs out and see if the engine will turn over and blow the water out. Was your filter damp aswell?
Old 07-12-2009, 07:20 PM
mkjeep's Avatar
Arrrr, I type slow.Beat me to it.
Old 07-12-2009, 07:43 PM
JEEPSHANE's Avatar
I have an open CAI and jumped into a puddle one time i sucked up a s**t load of water, she died immediately. i stalled out in about 20 inches of water in the middle of this pond, it had taken me like 10 cranks and she finally turned over. so i dont think it the water damage because mine pushed whatever water was in her out, i think its an electrical problem. also when your battery is almost dead it does the same thing. just clicks.
Old 07-12-2009, 08:19 PM
LaxAHolic's Avatar
im going to take the rest of the plugs out in the morning and see if itll turn over and push the rest of the water out. if not..anyone wana trade?
Old 07-12-2009, 10:03 PM
The_Captain's Avatar
take the hose from the air box to the engine off, it is a large rubber hose, 3-4 inches. If there is water spots in that you maybe got water in the engine. When the jeep died, did it sputter and just die, or did it make a violent knocking sound? If it just died, and you heard/felt your engine slowly sputter out and cut off, I would say you are fine but if you engine went from 2k rmps to 0 in a second you may need to worry... try the spark plugs and give us some more info...
How deep, how fast, how far did you make it? Stock air box?
Old 07-13-2009, 09:12 AM
LaxAHolic's Avatar
its gota be the starter..but guess what. THEY DONT EXIST!!! anywhere..
Old 07-13-2009, 09:13 AM
LaxAHolic's Avatar
it immediately stopped...just kinda slowly died.
no knocking or anything. may look into an aftermarket starter
Quick Reply: Jeep wont run!!! Help!!!
