How well is the JK sealed from water?
Old 01-27-2009 | 04:54 AM
Jeepin Dad's Avatar
Originally Posted by simon
I have the Mopar door sill guards. Hmmm....... I guess I'll let you know. Does anyone else have these and still are fairly sealed?
I have the sill gaurds and have been stuck in a hole where the water was up to about the bottom door hinge, had to sit there a few minutes while the tow strap was hooked up and the the carpet was a little damp around the bottom of the door but nothing major.
Old 01-27-2009 | 01:54 PM
Ben's Avatar
Ben
The fan is also a weak point because it is not sealed. Water isn't as bad as it getting clogged with mud. And I have to ask, why are you worried about water seeping in under the door? You should take your carpet out when you wheel anyways, even if you aren't worried about keeping it clean. It smells awful when it is damp. And it goes in and out so easy, there is no reason to leave it in and take a chance of moisture seeping in through the rubber and getting it wet.
Ben's Avatar
Ben
also, extend your tranny/transmission/front/rear diff breathers. It is cheap and easy insurance. Ask me how if you have any questions finding them.
Old 01-28-2009 | 08:58 AM
simon's Avatar
I'm not necessarily worried about water entering, just curious how well the doors seal.
Already taken care of. It is as high as it can go.
Old 01-28-2009 | 09:34 AM
2climbbig's Avatar
Don't forget the breather on your evap can. It goes to your gas tank intake area.
Old 01-28-2009 | 09:51 AM
dyolfknip's Avatar
I have done a crossing to about even with my fenders and i have about 3 " of lift. (I started backing out when I saw the ass end of the 4 door in front of me start floating...he had a snorkel, not me) When I went that deep I had water come up from the bottom of my shifter..I actually saw it pouring in from there....mine is a 6 speed. By the time I had gotten out and stopped I had about 4 inches of water in my footwells.
Here is the thread from that experience:
https://www.jk-forum.com/forums/show...hlight=lingham
Old 01-28-2009 | 11:57 AM
simon's Avatar
Where exactly does it go? Near the filler neck?
I haven't heightened that one yet.
Old 01-28-2009 | 12:37 PM
Ben's Avatar
Ben
nor have i, but i try to keep my gas cap above water as it is not sealed and can let water in. But you gotta think, if ur gas cap is below water, that is some pretty deep water. I would never purposefully (sp?) go into water that deep!
Old 01-28-2009 | 05:56 PM
SiliconTi's Avatar
Mine leaked last time, but I found that one of the plugs was not in correctly and one was not sealed due to sound deadening material caught in it. Check yours first.
Old 01-28-2009 | 06:16 PM
sgmrock's Avatar
We have had ours in water to the top of the underside of the fender flairs...and stayed completely dry!
