how much will a 2d hemi tow
Don't forget overheating. The V-8 cooling system will have to reject add a lot more heat than the stock system. Unloaded or city / freeway driving may be fine. But even with an upgraded cooling system, it may not be able to handle the amount of heat generated by the V-8 under load.
I think in this case the jeep will be able to tow the trailer. However, you have to ask yourself if its worth it to try. Towing on smooth flat roadway would not be too hard. Now try it on hilly, rough, or windy roads and it could be downright dangerous.
Again though you need to ask yourself if its work the risk. If you would get in a accident you could be found at fault for towing over the capacity of your vehicle. Even if you were not the cause of the accident. Another possibility is if a police officer decides what you are doing just doesn't look right and decides to check. Its quite a healthy fine and the trailer will have to be left there to be picked up by a suitable vehicle.
My previous JK was a 2dr with tow package. I used to pull an ATV trailer with 2 atvs and gear ~1500lbs and it was easy with no problems. I would use the factory specs for a 2Dr with tow package which is 2000lbs.
As has been mentioned, a lot of towing capacity has to do with wheel base and counter-weight. Both of which the JK is lacking in.
I'd pull a small boat or a pair of jetski's without reservation, but anything over that I think you'd be foolish, HEMI or not.
I agree, adding a HEMI doesn't increase your towing capacity at all - it just makes it a lot easier on your engine at full load.
I have pulled 2 large 4 wheelers with trailer(about 1800 pounds) . I felt very secure with that load. You would need to make sure the hitch weight is correct and you need to remember it is back there. The braking was definitely longer but trailed straight. I have a 4" lift, 35s and 4:88 gears with an auto. under 2000# and balanced out correctly you should be fine.
