How many miles do you get to a tank!!
#31
Originally Posted by ZMagic97
With bigger tires your speedometer is off (it will read lower speed than actual). So, when you're doing 55MPH (Closer to 65 actual is running 35's tires) your Jeep registers you doing 55 MPH via Distance/Time. So less distance (via speedometer reeding low) over the same times means your Jeep thinks it isn't going as far, so it feels like you are using more gas per mile than you really are. Re-calibration for bigger tires (up to 32" I believe) is available from the dealer. Anything more can be done with the AEV Procal. So, for example prior to re-calibration it said I was getting like 200 gallon per tanks, via the DTE and tripometer (miles divided by gallons). Which makes sense because they were both reading the same source. When the sourse is changed (i.e. re-calibrated), both numbers will change. Now I get 250's-300depending on my driving and the environment.
