How deep can the JKs go?
Old 09-05-2011 | 03:38 AM
rndptkea's Avatar
Originally Posted by matt852
As long as your in 4 Lo and keeping a constant speed through the water no excessive you should be good as long as it doesn't go over the intake your fine.
X2 , it's always risky but I would not go deeper than the intake, unless you have a snorkel, but even then it's risky I'd try avoid it...
Old 09-05-2011 | 04:06 AM
Mark Doiron's Avatar
Veteran: Air ForceFJOTM Winner
When the JKs first came out there were some instructional videos on the Jeep.com website and during one of those they mentioned thirty inches of water. However, I think officially it's like only 12" of water. Of course, the amount you can ford is going to vary with lifts/tire size since you're lifting almost all of the components that are affected by water--the diff's being the one exception. That's why you can extend the diffy lines, as previously mentioned.
However, do be aware that the diff's run quite hot and when they hit cold water the first thing they do is suck in stuff as quickly as they can. Most of that comes in through the breather hose. However, it is still possible for some water to be sucked in through the various seals. So, after any deep water run, you should make a quick check of your diffy fluid to make certain it's uncontaminated. While driving Medano Pass Trail in August, we had about a dozen water crossings. Upon return home I had already planned to change the fluids, and the rear axle was contaminated, slightly, by water.
Old 09-05-2011 | 07:33 AM
speed2005's Avatar
How do I do this? Sorry I am new to his kind of stuff. All my cars in the past were small FWD or Camaros and Firebirds
Old 09-05-2011 | 07:38 AM
Pull the fill plug (NOT the drain plug!). Reach through the hole and dip your finger into the fluid inside. If it comes out oily without any milkiness (even a tiny bit of milkiness), you're good. Be aware that it stinks like all get out.
BTW, my TATA:
Old 09-05-2011 | 08:50 AM
daggo66's Avatar
Have you guys ever considered reading the owner's manual?
Water ingestion into the axles, transmission, transfercase, engine or vehicle interior can occur if youdrive too fast or through too deep of water. Watercan cause permanent damage to engine, drivelineor other vehicle components, and your brakes willbe less effective once wet and/or muddy.
This vehicle is capable of crossing through waterat a depth of 30 inches (76 cm) at speeds no greaterthan 5 mph (8 km/h). Water ingestion can occur
causing damage to your vehicle
Old 09-05-2011 | 12:49 PM
baconrocket's Avatar
Deep so deep so deep, put her a** to sleep.
Old 09-05-2011 | 12:52 PM
speed2005's Avatar
my 2011 did not come with one
Old 09-05-2011 | 01:14 PM
AK4Dave's Avatar
Just wondering. Took the JK off-road for the first time and was amazed at what it goes trough.
I know the intake is at the very top of the hood, but how deep can we go before we get stuck or mess something up?
Does it matter if they are auto or manual?
Also understand.....that even tho "they" say water 30" deep, a big problem "can" occur if you get into water deep enough to cover the bottom of your radiator fan. If your fan happens to come on while you are in that deep, it can sling water all over the engine compartment AND into your intake. There have been plenty of guys around here that have hydrolocked from far less water than 30".
Old 09-05-2011 | 01:47 PM
pow3rhouse's Avatar
Sounds like a good day
