Hornblaster Train Horns - anyone have one?
#21
Now, stupid question.... With the tank in one location, the compressor in another, and the horns in yet another....is there enough wire/hose to accomodate multiple locations? Plus, I'm not sure if I heard right but if you mount the compressor under the tub, won't it get all the debris from the road and stuff and eventually seize the compressor?
In regards to the compressor succumbing to seizure from debris and water, according to the Viair, their compressors are, and don't quote me quoting them, water proof in the sense that all parts are sealed. Maybe the rep will chime in if we mention Viair enough??
#22
I've had that bug as well. I wouldn't ever use it to scare pedestrians though, only those drivers that cut in font of me or do something dangerous in traffic.
#23
Alright folks. Here is a video comparison between the stock horn and the Hornblasters Shocker XL.
I didn't shoot it in a very open space so the Hornblasters are a bit echoed, but you should get the idea.
http://youtu.be/Rqy0cI19G6A
Let me know what you think
#25
#26
I did the installation in phases. The On Board Air was actually put on by a local shop, but if you are somewhat mechanically inclined, you could do it.
Next was making the bracket to hold the horns behind the fan. This took awhile because I wanted to get the measurements exact and not have an issue with clearance between the belt and fan shroud. Then, I used some galvanized steel from a piece I found at Home Depot. Plus a rubber mallet and bent into shape.
The horns couldn't be easier to install. They came with all the correct fittings, tubing and even teflon applied to the threads. One thing they stress in the installation is to cut the tubing at a perfect 90 degree angle. If not, you are much more likely to have leaks and not as great sound quality.
All in all, I would say if I were to do everything in one sitting it would take about 5 - 6 hours.
#27
#28
The sound of the horns, I feel, are a perfect match between train and loudness. I say go for it.
I'll have to rig something for the horns... I see where there is room behind the fan, but need to make sure it clears all the belts, etc. Just how to make a bracket of sorts to make it work is another story.
#29
I just mounted my horns outside the frame rail, two on each side, facing backwards. air tank underneath the driver's seat with a big L bracket from lowe's. Valve by the transfer case kinda and compressor on inside of frame rail passenger side where the gas tank shield ends towards the front.
