Help with Repair Necessities!
Hey Guys,
I just got a diagnostic report back from the Jeep dealership and they came back with a lot of stuff wrong with my '13 JK Sahara Unlimited, 4-inch lift w/35's. It has 129,000 miles on it and runs perfectly fine with no issues to my knowledge, besides brakes being pretty bad. I only got it checked out because I'm moving to Orlando soon and don't want to deal with anything going wrong when I move there.
I attached a picture of the report they sent me with the price tag of about $4,100. I am a broke 24 year old and already have student loan debt. I am going to medical school next fall so I won't have money for a while and I do NOT want to sell my first and only car ever.
Basically what I am asking is if someone could tell me what the absolute necessary repairs are that I need to get done ASAP on this repair report. Also, if you think they are overcharging for any of these services, please let me know so I can find another place to get my jeep serviced. Thank you guys.
You are at a tranny service interval, so dropping the pan, swapping the filter, and refilling with new fluids is normal. I have a '13 that I changed my tranny fluid at 60k and reused the gasket. I might change it this next time I do mine around 120k.
On the rear bearings and seals. Are you leaking gear oil all over your e-brake assemblies? If so, then you do need those seals changed and do the bearings at the same time. If you are not leaking anything back there you could keep on going till you do. (****edit....sorry, I just now saw they note both sides leaking)
No reason that I see to replace your front DS unless you have blown the CV seal and joint at the transfer case side. You can look.....do you see a stripe of grease on the underside of the tub right above that? If so, you could 1) find another factory DS for cheap on FBM or CL locally, 2) replace just that TC side joint with a Teraflex high angle CV, or 3) replace the DS. (****edit....sorry, I just now saw they noted torn boot)
If you've never replaced spark plugs then it's bout time ("tune up") and the upper intake has to come off to get to the driver's side which is why those upper intake gaskets are on the list too.
Serp belt, yes, it probably needs it.
Brakes are pretty self-explanatory.
After looking at that estimate again and seeing their comments I missed previously, it seems they did a decent inspection on few of the common things. You can save some money on that DS with just replacing that TC side joint though....but still couple hundred.
user 729872082 (06-29-2022)
You might want to get friends who know how to wrench as what the responses stated, pretty much normal repairs especially with that enormous lift. Don't know why both seals went on the rear as it is usually one or other. Stay away from the dealers as they work on flat rates to repair something. EG 1 hour to change a fan belt when it takes me about 3 minutes.
