Help! Dealer ordered wrong option, when I asked them to fix that, they ask for $$$
#41
Rip ... Panda is correct. I've built a 2012 Rubi several times over the past 4-5 months and the U.S. site did default to 4.10s when you ordered the Max Tow Package. Initially it would load 3.73s when you selected 5-speed auto trans and then would change to 4.10s after selecting the Max Tow option...
I posted about this issue before, the Jeep Web site can't be trusted for ordering.
The issue... he should have received the 4.10s with the Max Tow Package, PERIOD. Typically changing the gear ratio impacts the tow rating on most vehicles. The Jeep specs are all hosed up just like their Web site.
I would fight them all the way to small claims court...
.02
.02
#42
I just spoke with a Jeep representative and asked which axle ratio the Rubicon came with if it was Automatic - she said 4.10.
Granted that she used the jeep.com site - I guess they do not have any other tools for checking that.
#43
I just spoke with another Jeep representative, she used two internal tools plus the website - took a lot longer with the research than the previous one. She states that the website is correct - 4.10 is the option that is standard on the Rubicon no matter what the transmission selection is. There is an option to select 3.73, but it is NOT a standard option when you switch from manual to automatic and should NOT be selected automatically. The website behaves properly. Now, what to do with the dealer whose argument that the reason I am wrong is that their system is preselecting 3.73 is beyond me at this moment.
The previous rep also said they would offer no help in resolving the issue with the dealer. This one didn't mention anything and also didn't start yelling at me right away.
#44
#45
These systems don't always work the way you think they should when ordering a vehicle... sales groups, defaults and exceptions are difficult to communicate between the customer, salesperson and the "Fleet Manager" on a custom order. That's why I go directly to the fleet manager when ordering a new vehicle and get the build and sales order sheet right direct out of the "system" ... invoice price and all.
I would call a fleet manager at another dealer to get the facts straight...
You may just want to live with the 3.73s and drop it down a gear when towing ... rpms are rpms. The pistons don't know jack shit about what gear ratio the Jeep has. Speed should be dropped to 55 when towing anyway.. Calif law.
Good luck....
#46
If I did, this post wouldn't happen. I don't want to.
#48
Nope. Sorry.
The Web site since was updated with no clear understanding what is standard, optional and the defaults under various option packages.
... using the "build it" function.
#49
The dealer made the mistake and should fix it! Since it is an option that you dont show on either of your two order confirmations you can now prove it is the dealers mistake. They need to fix it! If the dealer feels the mistake is with jeep and their order system the dealer still needs to fix your jeep at the dealers cost then go back to jeep for reimbursement.
Bottom line the dealer is responsible since they placed the order! They need to fix your jeep and keep warranty or they can buy it back from you(giving total purchase price back). This second option would cost them far more money than swapping gears!
Also since it is an option the 3.73 gears should be listed on the window sticker. If it is not, there may have been a mistake at the factory?
#50
Wow the Jeep rep started yelling right away?
See attached ... the Web site clearly indicates the 3.73s are standard with a 5-speed automatic .... !
