Help!!! Check engine light 2014
Old 11-08-2013 | 10:06 AM
Patty11190's Avatar
Default Help!!! Check engine light 2014
Started my 2014 jku with 4k miles on it and it started shaking ... Turned it off then back on still shaking put it in drive still shaking .. Then check engine light is on but it stopped shaking so I drove it ... Any ideas?????
Old 11-08-2013 | 10:47 AM
BillyJack's Avatar
Check to see what code you're throwing. I'll assume that it's checked the same was as the first generation JK. Feel free to correct me if I'm wrong.
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Diagnostic Trouble Codes DTC How to Check Them
Old 11-08-2013 | 04:31 PM
Patty11190's Avatar
P0300 code?
Old 11-08-2013 | 04:48 PM
Spencer4336's Avatar
Originally Posted by Patty11190
P0300 code?
Just googled it and I got this
P0300 Jeep - Cylinder Misfire Fault Detected Random Cylinders
Old 11-08-2013 | 06:51 PM
MOPWR2U's Avatar
Why are you even worrying about it. Its under warranty. Take it back and let Jeep fix it.
Old 11-08-2013 | 07:00 PM
I second that
Old 11-08-2013 | 07:10 PM
MarineArmyJeeper's Avatar
Originally Posted by Spencer4336
I second that
Third......
Old 11-08-2013 | 07:49 PM
ShutterBug's Avatar
Originally Posted by MarineArmyJeeper
Third......
Seriously.
Old 11-09-2013 | 06:36 AM
BillyJack's Avatar
I would just disconnect the battery to clear the code and see if it happened again.
Old 11-09-2013 | 07:40 AM
catahoula's Avatar
Now if you keep driving it and not take it in can that void the warranty? I don't know why someone would though.
