Help any idea's?
Help any idea's?
I bought this 2013 jk it had 17" wheels and 33's. Also had a lift from spacer's 3" front and 2.5" rear. I did away with all that and added a Teraflex 2.5" coil and shocks lift, 15x8 fuel revolvers with 35" ko2's should have went with an MT in hindsight..next time! Added front bumper and winch, rock slider rails with built in step and rear bumper with bumper mounted tire carrier. I removed some vinyl decals and am going to remove the rest. Now I'm eyeballing several different fender flares. This is where I need some helpful advice. Flat fenders? Pocket style flares factory coverage or what?
Well crap I'm posting this but it's useless without pictures!
I don't see where I can add pics to my post what gives?
I think I'm with you on that. I've been trying to find pictures online of my set up on other 2 door jk's with different types flares. I can't seem to find hardly any of the bushwacker pocket flares that are just factory coverage I keep seeing the oversized ones and mostly on 4 doors so I can't really tell how it would look. And everybody has flat fenders it would seem.
Are you going to wheel that jeep, and if so, how aggressively? Plastic flares don't typically fare well on the trails when the goin' gets rough. It's not a huge deal for factory flares as you can source cheap replacements from people taking them off, but I can tell you first hand it sux to replace Bushwackers. I finally did away with mine. If you don't like flat flares, are going to stick with plastic, and you are going to wheel, then I'd stick with factory and be done. I don't mind the look of the factory flares, but hated grinding on them. I moved to flat bushwackers that I hated just as much, and now I'm fenderless with some Gen Right deletes.
Would you be able to tell me how to post pictures on this site? I can't seem to figure it out. Does not seem to be a way to do it. I'm using my iPhone.
Most people go with flat fenders for function.....and likewise with steel or aluminum. If you're just in it for the looks, the decision is a lot more subjective. It is definitely a bit harder to justify spending up to double for metal fenders just for the looks alone. As a person that had bushwackers, I think the Aries would have been a better choice. The bushwackers were so wide.
Every upgrade I've ever done has had an opportunity cost associated with it......as in...if i didn't spend several hundred on this item, what other upgrade would I do instead? If you kinda like the classic look and kept the factory flares, what would you spend that several hundred bucks on instead??
Are you using an app on the iPhone or just the site through a browser? I have an android and it's straight forward on that app.
Thanks!
I'd think they have an app for iOS, but not sure. I tried on my phone and through chrome on the site....it's a lot more of a pain. I can see where to do it, but when you have to click and drag the pic to the proper place the phone functionality gets messed up. On the website, down below the section you type your reply, you should see a spot to manage the attachments.
Oh, and if your avatar is the current look, I think the factory fenders look good with the full width bumper. If you chose a stubby bumper, it would look a bit odd.
I'd think they have an app for iOS, but not sure. I tried on my phone and through chrome on the site....it's a lot more of a pain. I can see where to do it, but when you have to click and drag the pic to the proper place the phone functionality gets messed up. On the website, down below the section you type your reply, you should see a spot to manage the attachments. Oh, and if your avatar is the current look, I think the factory fenders look good with the full width bumper. If you chose a stubby bumper, it would look a bit odd.
