Handing rust around the window bolts.
How to tackle this rust around the bolts near the window? Not sure if this is a DIY since it seems small but since it’s on the body I’m unsure how to handle it.
If you've got rust there then pull off that entire piece (6 bolts) and check the back side of it. You may be surprised. To get rid of that rust though, lightly sand it, spray some matching paint, spray some clear. I would be tempted to just paint the rusty spots but the reality is that you'd probably need to go 1/8-1/4" all the way around to make sure the rust isn't bubbling and spreading underneath the paint.
QuantumAgent (07-03-2020)
I'm just trying to be helpful and nut insulting, Jeep sells touch-up paint that comes with a brush on one end and a pen on the other. You may be able just to sand and then touch up a very small area. to correct the rust. https://www.quadratec.com/products/9...xoCJRIQAvD_BwE
Some people may take offense, Anyway I have used the Mopar paint pen to fix small areas on my JK and have been happy with the results. Patience is my go to philosophy. , Mopar also sells 8 oz spray paint. cans, Good luck !
