GPS+ tracking and GoPro
For several years starting in 2005 I used the DeLorme Topo USA and Earthmate GPS reciever to map my trails in Moab. I would have the laptop mounted to the dash, and the GPS receiver plugged into the USB port. It would map my exact location every few seconds, creating a breadcrumb trail of the trail or road I was on. I was using version 5 way back when, and now they are up to version 9. For $100 you can get the software and GPS bundled. It should do exactly what you are looking for.
hxxp://shop.delorme.com/OA_HTML/DELibeCCtdItemDetail.jsp?item=31586§ion=10091
This also looks great but unfortunately it seems their website is down and the app can't connect to register me either :( Not sure what's up with that but have tried since you mentioned it and it does look exactly like what I want!
This doesn't solve your plotting question, but some DSLR cameras have GPS attachments you can get to do the same thing the iPhone does. I have a Nikon DSLR with the GPS marking feature. Sorry, not much help to the other part of your question. I think Garmin makes a hand held portable GPS that might work for your needs. They make running watches that plot courses on maps.
Will this recognize the path it's travelled though or just a planned route? I want to track rather than just import a planned route. I may use this to load a course onto the gps so it goes the way I want rather than the "optimal" path. Lots of places I want to go through on the way to Alaska that probably won't be the gps first choice haha
Not sure if it's been mentioned already, but if you're an iPhone user and want to have NAV / Plotting / Topo info, take a look at Gaia GPS. Actually got turned on to this by our own WOL from a post he did on his Journey to the Corner of Nowhere. Been using it since then and love it.
The Garmin Edge Series are really nice. I have the 205 and the 305. After you record your route, you can upload to connect.garmin.com
They will retain a history or all your rides... forever! and best of all it's free. I use this when ever I jump on my bikes. I record every mountain, commute and road ride I do, so I can calculate miles, elevation, calories, etc. Plus, you can use teh Garmin to find your way back if need to and has an off road feature as well - on the 305. The newer models have longer battery life and touch pad. and you can export to Google earth as well or to your GPS if you want to follow the route at a later point in time. When trasferring to google earth, google earth will keep a history so you can also see all your rides on the US map. Pretty much any phone has the GPS picture tracking.
Jeff
Jeff
I use a stand-alone device that logs your GPS coords by time. When you upload your pictures to your computer, you can sync the GPS logger with the timestamp on your pictures, and the software embeds the GPS coords into the images EXIF data. Once the GPS points are embedded, you can then plot them on a map. I use Picasa for web albums. Here is an example - https://picasaweb.google.com/NuRVers...eat=directlink
I use the Amod AGL3080 GPS Data Logger, found on Amazon - http://www.amazon.com/gp/product/B00...00_i00_details
If I remember correctly, the most difficult part is to keep the times between the logger and the camera coordinated. The logger software allows you to do time adjustments (plus or minus time) to get the plots correct.
Nice pics at moab there, I wish I could afford to head there for the Easter run but if I want to do this trip to Alaska I have to save pennies haha
