Got a flat.
Got a flat.
Well, last Sunday I took the jeep out to wash it, and the TPMS indicator was on. Sure enough, I've got a nail in my passenger rear tire. Of course the tires are practically brand new, and only have 2200 miles on them.
My question is, should I put the tire back on in it's original position, or just leave it on as the spare. I've had the tire fixed, and currently have it on the tire carrier. I haven't even done the first tire rotation yet.
Let me know what you think.
db1
db1
db1
db1
when i took a chunk out of the sidewall on one of my stock tires I rotated that one out safety reasons and put the spare in. Still havent had the tire fixed or replaced, the only problem I saw with switching it out is it was dirty and looked like ass on the back. Little scrubing and it was good. Its made to be dirty anyways.
2200 is not that many miles for a set of tires and if your worried about rotating out tread i guess it would depend on how run down your other 3 tires are.
thats what i think but its up to you in the end. does it really matter that much?
for a plug in the tread... i wouldn't hesitate to run it. rotate it in. i have not had a problem with a plug leaking at a later date. it either works or it doesn't the first time. i'm sure there are people that have other feelings. i say go for it. i'm running on a plug in my driver rear from a roofing nail right now.
i would not worry about running a tire with a plug or a patch in the tread. If in the sidewall you should use it as a spare or replace it
I have run tires for years with plugs in them and never had any trouble. I seem to be a nail magnet, in fact just put a plug in my right rear tire this week for a nail.
Pluged/patched on tread I would run the hell out of it and have done so with other tires on many occasions. If it were on the sidewall or missing a piece on the spare carrier it goes only to be used in emergency situations and as soon as I have the spare change I will replace it.
I would not worry about it if it is plugged in the tread. I used to plug tires and they are made to be as strong as original depending on style of plug. You should be fine with rotating it in. i have never had any problems even while towing with a tire plugged on the rear.
