Good spot for a set of fure extinguishers??
I've had on on the back of the roll cage for years. It doesn't interfere with the top as long as you make sure it's in the right position and hasn't slid around when you raise or lower the top.
Those look like they have pretty wide handles. That might be a problem. The extinguishers I have came with much more compact handles/triggers.
I have one just like those, and I mounted it on the rear roll bar (driver's side). I actually haven't had my soft top on with it installed, though I do have the bracket attached to the roll bar for the soft top. I mounted the extinguisher below the bracket. I may have to move it around some once I put the soft top on.... I hadn't even thought about that.
