Going Spare-less
Going Spare-less
What should one do in order to go spare less??? Just carry a can of fix a flat???
I'll be ordering a bike rack tomorrow, and I may not be able to clear the spare. So, to get to the mountain, I may need to rip the spare off temporarily.
Will that vent be fine too??? I'm going to have passengers in the rear, and they're just starting to get over a very cold doors off-top off 1 hour highway cruise from over the summer. I don't want them to NEVER get back into my jeep again if it's freezing.
Way, hey dog, as a Tire Center employee, we don't recommend fix-a-flat...that stuff corrodes the sidewalls if it's in there long enough. I think ARB makes a flat repair kit with plugs, cement, and the like. Just a thought.
Russ D.
Is there anyway you can put the spare in the back storage area? If you did have to use fix-a-flat, you won't be able to have the tire properly repaired by a shop. I've used it a couple of times (on smaller car tires) and was a very temporary fix, but didn't last long.
drawtite-hitches.com/products/Receiver%20Extension,80307
There are also bike racks that mount to the spare. The huge advantage with them is you can still get into the tailgate without removing the bikes.
I highly recomend that you don't use fix a flat solution. The best thing to actually use is a tire repair kit and an on board air system like the Source here is a link for it. Good Luck http://www.offroadairstore.com/servl...ce+CO2+Systems
