Going Pantless?
If your trimming the fenders and keeping some of the inners - When cutting the outers only cut the inners the VERY MINIMUM needed to get the outers finished to your desired shape. I chopped both together and took too much off one of the inners. Obvious in hindsight, but it's too easy to chop more and then regret.
I was reading my post and noticed that i should clarify. When i said that i used some of what i cut off to close the gap, i was talking about some of what i cut off the fender flare. The part i cut off followed the contour of the fender perfectly and allowed me to make a closure for the gap between the actual sheetmetal of the fender and the fender liner. Hope this helps.
corey d
corey d
You can then zip tie the skirt through the holes and around the body mount.
If you check the xenon fender write-up in the write-up section there are some good pictures there. I used the zip-tie method as I wanted to secure the fender skirt but didn't want to drill the frame.
Steve
