Gearing
Just wondering what would be a good gear ratio to go with, I would like to keep decent fuel mileage, I'm not an aggressive off roader so I don't need anything super low, just pull my boats, a few other toys, and ride in the woods during hunting season...
![](https://www.jk-forum.com/forums/images/ranks/veteran_navy.png)
https://www.jk-forum.com/forums/modi...imited-213377/
Lift has nothing to do with gear selection, it does however provide for going with a bigger tire later on.
Hope this helps.
R/
Will
I went with 4.56 on 35s and a 13 auto. Drives great on the road and is still plenty capable on the trails. However if you're pulling a heavy load often, 4.88 may be the better option
I won't be pulling anything real heavy, the main thing I pull is my boat and occasionally my rhino during hunting season, I'm kind of thinking about going with a set of 4.10's but I'd like to get some input from someone running that set up before I do it.
I'm basically Running 34's and I have 3.73's. Around town I get 15 MPG and on the highway 55+ MPH its 18MPG. I don't Tow anything so no info to share on that regard.
Offloading I'm able to do the same stuff as the guys with 4.88's and I don't get high revs at 70MPH on the highway. 50 MPH I'm right above the green dashes in 4th gear. What people fail to understand 5th and 6th gear are overdrive gears your not supposed to have power in those gears thats why they are considered overdrive gears. 4th gear is supposed to be a 1 to 1 drive ratio. Most manufacturers still go by this guideline to date.
I'm basically Running 34's and I have 3.73's. Around town I get 15 MPG and on the highway 55+ MPH its 18MPG. I don't Tow anything so no info to share on that regard. Offloading I'm able to do the same stuff as the guys with 4.88's and I don't get high revs at 70MPH on the highway. 50 MPH I'm right above the green dashes in 4th gear. What people fail to understand 5th and 6th gear are overdrive gears your not supposed to have power in those gears thats why they are considered overdrive gears. 4th gear is supposed to be a 1 to 1 drive ratio. Most manufacturers still go by this guideline to date.
What guideline are you referencing?
They are considered overdrive because they are 'over driving' the driveshaft (spinning it faster than the crankshaft) not because there should or should not be power available.
Take a look at thrust curves for various gear/final/tire size combinations, that is where the story is. If I put 48" tires on my 4.10 diff'd 6 speed JK then sure I'm not accelerating in 5th or 6th. Heck I'm probably not accelerating in 3rd or 4th either and I will be burning up the clutch in first starting out, if I put the stock sized tires back on it feels like a go cart, pretty darn fun.
