gear install.. how much should i pay?
Old 12-30-2008, 05:19 PM
08SaharaM6's Avatar
Originally Posted by AZJeeper
Point taken. Most of these threads are rather generic on "install". I guess I would have been less confused if the OP said "...how much it should cost for labor for a competent shop to install gears..."
Now if smbundy13 could clarify - does "install" simply mean labor (i.e. you'll supply the parts) or are you asking what it takes for the whole enchilada?
Sorry, didnt mean to come off like a dick. I was just pointing out, that I was wasnt losing my mind and he didnt ask about the price of the parts(directly)!
Old 12-30-2008, 05:38 PM
2climbbig's Avatar
Wow... my neigbor just put in 4:56s in his TJ for $300 per axle in labor.
Old 10-16-2009, 09:48 PM
DrummerShaneB's Avatar
How hard is the install?
Old 10-16-2009, 10:29 PM
BlackNorthernJK's Avatar
...really, it's not that bad, I mean if I can do it, anyone can...and actually...I would say it's probably a little easier than some installs because there's no need to constantly pull the carrier bearings to chagne shims, the shims are located on the outside of the bearings which in my opinion saves a little time, and no need for carrier set up bearings...the pinion still needs 'em, but I personally think alot of shops are over charging for this
Old 10-17-2009, 01:21 PM
spinlock's Avatar
How good are you with tools? Are you mechanically inclined?
How strong is your patience and your attention to detail?
Do you have a shop with a work bench or just a driveway?
On a scale of 1-10 if installing a lift kit is 5, IMO this job is a 7-8.
Old 10-17-2009, 01:29 PM
Randy Watson's Avatar
Does anyone know of a trustworthy shop in the north Phoenix area that could do the install? I assume that I should stick with a shop that does a fair amount of 4x4 work. Thanks!
Old 10-17-2009, 07:32 PM
AZJeeper's Avatar
I got a custom drive shaft and install at Phoenix Rack and Axle. Not exactly north Phoenix, but they did a great job.
Had good luck with Desert Rat for other work done - they did my gears and an s-load of other work.
Old 10-17-2009, 07:38 PM
joe002's Avatar
I had mine done at Absolute Offroad. Ask for Joe - the owner. He runs a great 4x4 job and has personally done many gear swaps.
Old 11-10-2009, 08:10 PM
jeepnyak's Avatar
I spent $850 out the door for my 5.13's to be installed today in houston
Old 11-11-2009, 07:10 AM
hammerhead's Avatar
Local guy who was highly recommended by several people that have re geared is $200 per axle. He works out of his home garage so he has no overhead. Local shop that was also recommended is $300 per axle. Both quotes were for labor only.
Quick Reply: gear install.. how much should i pay?
