Extreme Cold Tire PSI?
#21
Thanks for the info!! Looking forward to it!
You ship it up on the barge. Going to Iqaluit you will probably have to use the barge in Montreal. NSSI it is called "Nunavut Sealink and Supply".
Iqaluit has more roads than we do but you won't be able to drive out of town anywhere. Should be lots of nice off road adventures for you there!
#23
I need to adjust the TP monitoring settings on my Flashpaq. Last weekend when it got down into the teens, the light came on and wouldn't go off till yesterday. I checked the pressure a few times, with a quality gauge, when it was cold and the lowest I saw it register on any of the tires was 34 PSI.
#24
Remember that the cold make psi go down... Try 14-18 psi and it should settle at 12ish in the cold... OR wait till the cold and add air until 12 psi... That low a pressure can be bad if you have to brake and turn suddenly, I would stick to 20's at the lowest for non off road driving... 30 for pavement, but you don't need to worry about that....
#26
