Extreme Cold Tire PSI?
Old 10-05-2009, 03:16 PM
MJK
MJK's Avatar
Default Extreme Cold Tire PSI?
I am running 35 X 12.5 Micky Thompson Baja Claws. I live in Nunavut where it gets to -50.
I am currently running at 12PSI becuase there are no paved roads and it makes the ride smoother.
On the tire wall it says 70PSI COLD or something like that but realistically, what should I run at in extreme cold?
Thanks.
Old 10-05-2009, 03:27 PM
m_syer's Avatar
I am also curious about this! Sorry I don't have an answer for you... I'm just looking to hear what everyone else has to say aswell.
Old 10-05-2009, 03:39 PM
john smack's Avatar
run the same pressure as you run now, I live in fort st john and we regularly see -40, you get flat spots but they go away quick. I am running 35x12.5 procomp x-terrains and I usually run 20psi all year round
Old 10-05-2009, 03:43 PM
Yoda's Avatar
minus 50!!!!!!
Old 10-05-2009, 03:45 PM
MJK
MJK's Avatar
Will there be a big difference running 12 or 20 PSI?
Why would the sidewall say to keep at a high PSI for COLD?
It can get to -60 here without wind chill on some days.
Old 10-05-2009, 03:48 PM
ronjenx's Avatar
Thanks.
That 70psi is probably max pressure for max load.
12psi seems low enough to cause sidewall damage with extended use. Maybe not, I can't see the tire.
Anyway, run what works without damaging the tire. Bring the pressure back up when the cold temps cause it to drop off.
Old 10-05-2009, 04:57 PM
horwitzs's Avatar
Originally Posted by JK Freedom
minus 50!!!!!!
If that's a celcius temp, it is actually warmer than -50 farenheit.
The temp scales meet at -40, below that the F temps are colder.
(maybe I've said that backwards somehow, but you get the point)
Not that it matters too much in this topic, just some trivia I guess.
Old 10-05-2009, 05:01 PM
ronjenx's Avatar
When it gets to -30F here in Maine, I can't tell the difference between that and -40F.
-50F is -45C
-50C is -58F
Old 10-06-2009, 06:50 AM
CdnJeepDan's Avatar
Send the manufacturer an email and ask them?
Old 10-06-2009, 08:56 AM
john smack's Avatar
you will be fine its not like the tire is going to explode, run a tire pressure you are comfortable with
Quick Reply: Extreme Cold Tire PSI?
