Driving in 4wd Hi - new Jeeper
This is my first post in this forum.. (other than the posts for the MBRP giveaway..
My question is: why does it feel awkward when driving in 4wd hi on streets? Especially when turning or making a U-turn.
I have a 2011 JK sahara stock..
Thanks..
Thanks..
I feels awkward because you are tearing your Jeep up. Read your manual. If it's your first 4wd, keep it out of 4wd when you are on pavement.... Unless the pavement is covered in snow...
I just use it when I'm on sand dunes and the tires are aired down..
I thought something is wrong with my Jeep that's all..
Originally Posted by AlexTen
Well. That is why I think that Jeep needs 4 wd alltime.
LOVE my jeep the way it is.. It needs a little boost though..
Originally Posted by EzK
As I mentioned before I don't use it on pavements.. But I was wondering why it acts weird and the link explained it all... Thanks a million buddy..
"Continued 4WD use on dry surfaces will cause the weakest links to break (U-Joints, axles, differential gears, transfer case gears and chains, bearings, drive shafts)."
Welcome to the forum! Wow getting flamed on your first post - that's brutal.
The other posters are right, though - do NOT use 4WD (hi or low) while on pavement. Your tires are firmly planted when you're on roads so if you make a turn, the inner tire rotates more during a tight turn and the outer one less (like track and field runners on the inner and outer lanes taking a corner). The 4WD system wants to rotate both tires at the same rate. So what happens is you're jamming up your inner tire badly and will eventually cause failure or wear to your front differential and shafts.
Hope this helps. And remember 4WD = only on loose ground/offroad.
