Does the Oil Change Light mean the JK needs oil?
Hey there... a couple of odd questions about what's going on with my JKU:
1.) Oil Change prompt light that dings everytime you start the Jeep has come on this week, yet I got an oil change less than a month ago and less than 2,000 miles ago. I am wondering if that indicator also reflects that the oil is low? Obviously I am going to check the oil this afternoon, but for the good of the forum I thought I would inquire.
2.) Rought idle... WTF!!! 40,000 miles and it idles rougher than my 1997 TJ with 150,000 miles! I am going to change the spark plugs as I have already cleaned the throttle body and added oil additive to clean out the valves... I asked the dealer, and like they always say "Technician could not replicate the problem." so I am on my own to fix... it is truly annoying though! Any other ideas or experiences out there?
3.) Just put 1.5" wheel spacers, and I get a slight wobble occassionally... does adding wheelspacers affect alignment or affect the balancing of the wheel. It just seems weird to have the wobble and again it is truly annoying
Thanks for the feedback in advance.
Jason
Jason
1) The oil light comes on for some reason other than needs oil or change almost like a timer. I will change oil and have the light come on in less than a week.
3) I got no wobble from my Spidertrax spacer on either of my jeeps. I took off the retainer clips from the axles.
Jason
Jason
as far a the rough idle mine started at 5000km it comes and goes I think it's a computer control issue. it shouldn't stall. you could try putting in better spark plugs make sure they are gapped to vehicle specs.
your wheel spacers should be torqed progressively standard star pattern start with 30flbs then 60flbs then 90flbs be sure to use some red locktight on the threads holding the spacers on. if they are slightly off you will get a slight wobble.
hope some of this info helps
