Are Differential Covers worth it??
My Rubi has a 3" lift with 35's. I usually go to the desert, mostly on trails with a moderate amount of rock crawling. I haven't yet hit the diff. I've hit every other area, but I have those armored up, especially the gas tank. I'm just curious if an HD diff cover has prevented a catastrophe (or if not having one caused a catastrophe) and what were you doing when you hit the cover. I would assume the only diff cover you would need is the front but maybe I'm wrong. What are your opinions, pictures and stories??
I think they are helpful. Both front and rear. Front more so. My TJ one was ground down all over the bottom. Both front and rear. They do present clearance issues with suspension parts depending on your lift.
8 to 10 rigs out wheeling in Wenatchee National Forest. A few rocks, nothing major. All of a sudden, wham, I drop off a small shelf. And immediatley heard a grinding sound. Made it back to camp. And proceeded to drain and beat out my diff cover. Sheesh, and typical Northwest weather...it was raining.
Bob
Bob
I got the Riddler front for $109 shipped. It gives me peace of mind
I backed into something getting around a stuck F-150, pulled him out and when he was following me he came over the CB and said "I think you're leaking something in the back."
Sure enough, even though the hit didn't even dent the cover, it was leaking just slightly. Almost completely stopped the leak by tightening the diff bolts, right up till one snapped off (!!).
Ordered the ARBs & LubeLockers from David at Northridge the next day, slapped some silicone into the gap and it held untill the covers showed up.
We nail the front one ALOT.... so it has definitely paid for itself several times over I havent nailed the back one yet, but I have wheeled with people who have peeled the stock back cover up after sliding over a rock and Ive seen people do the same to the front. A leaky dif can ruin your whole day if you dont have the tools to fix it on the trail. So yes, I really think they are worth it
Like others have said, it is one of those things that if you break, it often puts your JK out of commission until you can get a replacement. I consider these to be in the same category as my engine skid - Not necessary, but definitely a good preventative measure.
