Dealership screw around
Old 04-27-2014, 12:10 PM
jrod250's Avatar
I'm assuming and assuming only, but since it has the after market mopar LCAs they should be of the proper length for the lift. Even if they are not adjustable.
Old 04-27-2014, 12:20 PM
Punkineater's Avatar
The LCA's should be fine. Adjustable is nice but if they were engineered with the lift you should be good. The pull to the left is likely in the steering. Did they replace your track bar or at the very least lower it with a bracket for the lift? Lifted JK's do have a tendency to pull slightly left but shouldn't dart that way and it shouldn't be super pronounced.
Old 04-27-2014, 01:00 PM
Jeepstercanada's Avatar
I have a friend with this lift she had the same problem. It turns out the lift used the factory track bar with no bracket. I changed the track bar and it drive normal again
Old 04-27-2014, 01:21 PM
Mr.T's Avatar
Originally Posted by Mr.T
Is it possible that the Fox steering Stab is pressurized, extending the shaft, and pushing left?
One could take the steering stab off, see if/how much pressure it applies left, and drive with it removed and see if the left pull goes away.
Old 04-27-2014, 03:16 PM
jaker t5's Avatar
It's a 4" lift and it looks like a stock track bar , if it is a stock track bar ( and I don't see any relocation mounts for it ) then you should look into getting a adjustable one first before you do anything else
Old 04-27-2014, 03:22 PM
jaker t5's Avatar
Wouldn't that push it right if it was pressurized
Old 04-27-2014, 03:36 PM
Mr.T's Avatar
I believe the rod end pushes on the tie rod in a left steer direction. The SS is in the first pic posted. Found this https://www.jk-forum.com/forums/modi...g-left-237557/ which might help the OP.
Old 04-27-2014, 03:53 PM
jaker t5's Avatar
I believe the rod end pushes on the tie rod in a left steer direction. The SS is in th first pic posted. Found this https://www.jk-forum.com/forums/modi...g-left-237557/ which might help the OP.
No you are right brain fart , I just home from being out wheeling and just forgot about drag link to knuckle
Maybe I should take a nap
Quick Reply: Dealership screw around
