Co2 Tank mounting locations
For use as an air supply for times when you air down going off road and need to air up after the ride - at least that is the primary reason that I know of. What you don't see in these pictures is the coil of hose that would be used to get to the tires. Other options are compressors / pumps in the engine area or under the jeep - those would be powered by the engine / battery. The other option is to buy a small portable unit (still powered by the battery). The cheap ones you can buy don't work well (I tried). Hope that helps.
I appreciate the courteous answer. It can be a bit daunting to ask newb questions, altho most of the members here are exceedingly gracious and patient.
Just don't search the forum to find all the stupid things I have said or asked! I try to answer the easy questions because usually I feel useless in terms of contributing back to the forum given all the great info everyone offers.
From: East Texas or Shreveport depending on the day
I failed to mention that in my post, I have a soft top. So mounting spots are limited due to the hardware on the roll bars. When I figure something out I'll post up some pics.
As far as the CO2 and why, I'm doing it so I can air up quickly. I weighed my options with electric compressors, and didn't want to go with an engine mounted one and a tank. It cost me $13 to fill up my tank and I can air up approx 40 tires with it. So about 10 trips I'll have to refill.
With the electric pump I have now last and only time I filled my tires it took me an hour to air up 4 tires from 13 to 40 lbs. I'm now running at 35lbs. With this tank I can air them up in about 30-45 sec per tire. Plus if you want to you can run air tools with co2. Not for long but it's possible. Before my trip to Co this summer I'll have a spare tank, so that will be equivalent to a lot of air.
I have a soft top to and I am having some issues figuring out where to mount it as well...IS there any reason why we can't just bolt it to the plastic cover, covering the little cubby hole in back? I am only planning on having my tank in when I go on trails, other than taking up space, is this ok? I was testing out the strength of it and it seams pretty sturdy, it seams like it can hold the weight and it is still easy to open... with the additional weight. Please let me know, Thanks!
Brian
BTW this isn't actually mounted, just placed for reference
Brian
