Cleaning under the hood
Old 07-28-2010, 07:41 PM
matt852's Avatar
Originally Posted by FunJK
I do the same exact thing, nice and easy and looks like new afterward plus simple green is ok for the environment.
I don't like the pressure washer idea, too much pressure on the sensors and such could force water into them where a nice easy spray from a hose wont.
Where are these sensors your talking about so next time I'll be extra careful.
Old 07-29-2010, 05:39 AM
goaterguy's Avatar
I never use "degreaser" if I am not cleaning grease or oil, It is too acidic and will spot the aluminum.
A 50/50 mix of an all purpose cleaner, Mr. Clean (lemon scent) has always worked for me.
Old 07-29-2010, 06:03 AM
MarwanJeeper's Avatar
i do oil wash every oil change..no issue yet
Old 10-20-2010, 05:29 PM
funtimes's Avatar
Dude are you using my jeep as your avitar....Gee thanks.
Old 10-20-2010, 07:34 PM
Incognito's Avatar
You can use regular dishwashing liquid (mixed with water in a bucket) which is a very mild degreaser. Work it in with a small short bristled paint brush. Work with small areas at the time and rinse often. A standard pressure household hose is all you really need to rinse it off. I like to do it with a cold engine and allow to air dry for a while. You can also towel dry if you don't want water spots. Afterwards, run the engine up to temp and/or on the highway. This will dry any remaining water. Follow up with some sort of protectant mainly for rubber & plastics.
Quick Reply: Cleaning under the hood
