Class of 2012
#362
Up to 1300 miles on my JK. Been a great experience so far!
Installed a LoD signature series mid width bumper and Engo with last weekend. Still have to wire the winch. Going to mount solenoid under the hood.
Attachment 352252
Jeep is Crush 2dr. Picture makes it look kinda Dozer.
Attachment 352252
When you said you were going to wire the solenoid under the hood... is that referring to the outlet where you plug the winch control into? I had a local JK owner tell me that the going fad now is to jumper the winch with a paperclip to control the cable and reel the cable out. Once out... they run the cable over the top of the Jeep and anchor it to the rear (bumper or axle?) and then using the paper clip they reel the cable back in etc... So I was told the best thing was to hook a switch and relay to control the winch power... so you'd have to activate the switch from inside the vehicle before the winch can be powered up.
Do you have a hood lock?
#365
#366
Originally Posted by maverick17
Now I like that bumper. I've been shopping around for a good winch bumper that allowed the stock fog lamps to be reused... now I need to price that bumper out... hmmm???
I don't have a hood lock. Might think about that.
#367
Yes, the solenoid is the control box/switch. Since the winch will be rarely used (I'm not a hard core offroader but like to be prepared). It'll be safer in the engine bay. Didn't have much choice, though as it didn't fit above the winch with this bumper.
I hear the Boy Scout motto there... for me the shopping list still has:
Front Winch bumper & winch
On board air compressor and tank
Hi Lift Jack
Shovel
Lift (larger tires later)
And then I should be fairly prepared to get into trouble... GRIN
#368
They stock vehicle rides so superbly, I'm going to attempt to avoid lift/larger tires. On all my jeeps, they've had some lift and it always makes for a crappier/louder ride. There are clear benefits, but they Rubicon is already a hell of a solid vehicle straight from there factory. (must keep telling myself this!)
#369
Originally Posted by Wendy.Jeepchick
How does your Rubi ride compare to your Sahara? My JKUR is much smoother stock that my JKUX was. I can actually feel the weight of the heavy duty suspension and axle. Did you notice that as well?
#370
