Cause of jeeping left and right
Old 06-24-2013 | 05:23 PM
Shoemakd's Avatar
While driving on different types of roads my jk doesn't like to stay straight. What do y'all think could be the cause ? Steering stabilizer or trak bar ? I have no idea. 2.5" teraflex lift bilstein shocks and 35's
Old 06-24-2013 | 05:51 PM
Twinkydog's Avatar
What tires and tire pressure are you running? Too much pressure and it can be like running on bowling balls and be all over the place.
Old 06-24-2013 | 06:01 PM
Cpfiremn's Avatar
Subscribed. I'm having same problem with 2.5 spacer lift, 35s and fox IPS
Old 06-24-2013 | 06:12 PM
Sgt Mack's Avatar
Alignment for starters.
Check the track bar heim joint hasn't wallowed out.
Ball joints stock? Wheel your stock axle hard? Are your C's bent?
Old 06-24-2013 | 06:23 PM
evoviii2jk's Avatar
I just pulled off my teraflex 2.5" coil lift with 5100s. The last drive with my new 35s it was all over the road. Changed to the aev 3.5" lift, problem solved. Feels stable as hell now
Old 06-24-2013 | 06:54 PM
Shoemakd's Avatar
Tire pressure is 30 all around. 315/75r17 duratracs
Shoemakd's Avatar
I've 2 alignments done ( which fixed steering wheel wobble ) haven't checked the track bar thanks
Old 06-24-2013 | 06:55 PM
Shoemakd's Avatar
Do you have problems with drive shaft angles or u joints with the 3.5" ? Which shocks are you using ?
Old 06-24-2013 | 07:01 PM
evoviii2jk's Avatar
No problems yet with drive shaft but that's due to the geometry correction brackets. Still haven't really flexed it though. I have the 5160 shocks as I'm running the aev RS kit
