Big Spare tire
Old 12-21-2007, 02:38 PM
08SaharaM6's Avatar
Default Big Spare tire
I will be getting 35's within the next couple weeks ,will the stock holder handle this? do I need anything to make it work?, I dont have the money for the rear bumper upgrade.
Old 12-21-2007, 02:44 PM
Renegade's Avatar
The stock carrier will handle most 35's little or no modification. It will likely rub on the bumper if you are using stock wheels, but won't be a problem. I had a 315/70-17 on mine for a while. It was a tight fit, but it worked.
Old 12-21-2007, 09:18 PM
SteelMastiff's Avatar
The added weight might be an issue long term...
Old 12-22-2007, 12:40 AM
ROKLIMO's Avatar
I just put 315/70R17 MTZ's on AEV Pintler wheels. The spare does not fit on the carrier. It hits the bumper. If I mount it on the carrier with the door open, I can't shut the door. Just ordered an adapter plate that shifts it out and up a bit.
Old 12-22-2007, 05:45 AM
Mowabb's Avatar
Thumbs up
With an adapter you can fit 37s on the stock carrier.
Old 12-22-2007, 07:53 PM
Dr. Satan's Avatar
Where did you guys get this adapter plate that moves the spare out and up?
Old 12-22-2007, 08:03 PM
08SaharaM6's Avatar
thanks for the help guys
Old 12-22-2007, 08:32 PM
Mowabb's Avatar
Expedtion One sells the adapter:
http://www.expeditionone.biz/JKsparetirebracket.htm
Old 12-22-2007, 09:54 PM
BigJerm's Avatar
35" will fit on the stock carrier. Depending on the rim you might need a wheel spacer but thats it.
Old 12-23-2007, 04:44 AM
bOLsAK=3's Avatar
Originally Posted by toad
35s will fit the stock tire carrier no problem. I just got them and was concerned about that as well. You can still see the 3rd brake light and the tire sits just in the cut out of the bumper. I'd say it was a perfect fit. Go and get those 35s! You don't have anything to worry about.
X2.... Nice tight fit that somehow just works!
Quick Reply: Big Spare tire
