ask pls need help
ask pls need help
as the title i want to ask why my speedometer there's " P R N D " right?
my speedometer like " P R N D "
my speedometer has "(.!.)" <<<< behind D shift
yah like that i don't know how to fix it help me plss
thx before
I'm sorry if I'm wrong I'm new here
thx before
Not exactly sure what you're asking? Troll maybe?...
If not then here's your answer:
P = Park
R = Reverse
N = Neutral
D = Drive (Transmission uses all gears in a normal fashion)
If you switch to 2 or 1 with your shift selector the number "2" or "1" will show up after the "D" on your dashboard indicator.
or that's the way my 2011 automatic works :P
P = Park
R = Reverse
N = Neutral
"(.!.)" This is the symbol for tire pressure, as previously answered correctly.
Upon ignition it will light momentarily, then go off.
If it stays on then one or more of Your tires are being read as having a
low pressure reading. If this happens, you should check to make sure
your tires have the pressure they are required to have via the inside
of the driver's side door jam.
