ARB diff covers
#22
Originally Posted by Torrin
The main issue between grade 5 and grade 8 is when you are using lube lockers. Grade 5 bolts can only be torqued to ~18fp, and lube lockers spec 30(?)ish. If you use RTV, grade 5 are not a problem.
I went with ARB's since they are stronger and they have grade 8 bolts, but they are not needed (stocks do not have them, and it is the weakness of the stamped steel that is the issue with stock diff covers, not the bolts)
#23
Originally Posted by RedJK2
Agreed - and I just confirmed this with Riddler Manufacturing. 17 ft lbs for Grade 5, and 25 ft lbs for Grade 8. You only need Grade 8 with LubeLockers.
#24
#25
#26
So just to confirm. They do come with grade 8 hardware and torque to 25 lbs?
I'm installing these with lube lockers Wednesday and their instructions say 30 lbs.
Sent from my PC36100 using Tapatalk
#27
