ARB diff covers
Old 03-12-2011, 08:40 PM
  #21
sringer's Avatar
Originally Posted by Torrin
The diff is 10x easier to do than a standard oil change imo.
after im shown one time then ill know.
Old 03-13-2011, 04:35 AM
  #22
RedJK2's Avatar
The main issue between grade 5 and grade 8 is when you are using lube lockers. Grade 5 bolts can only be torqued to ~18fp, and lube lockers spec 30(?)ish. If you use RTV, grade 5 are not a problem.
I went with ARB's since they are stronger and they have grade 8 bolts, but they are not needed (stocks do not have them, and it is the weakness of the stamped steel that is the issue with stock diff covers, not the bolts)
Agreed - and I just confirmed this with Riddler Manufacturing. 17 ft lbs for Grade 5, and 25 ft lbs for Grade 8. You only need Grade 8 with LubeLockers.
Old 03-13-2011, 06:40 AM
  #23
sringer's Avatar
Sweet. That's awesome! Thanks so much. Arb diff covers with lubelockers is the next addition :-)
Old 03-13-2011, 07:51 AM
  #24
Torrin's Avatar
Here ya go: Change Diff Fluid
Old 03-13-2011, 08:11 AM
  #25
sringer's Avatar
Haha thanks!
Old 03-13-2011, 08:24 AM
  #26
shockwaveaz's Avatar
So just to confirm. They do come with grade 8 hardware and torque to 25 lbs?
I'm installing these with lube lockers Wednesday and their instructions say 30 lbs.
Sent from my PC36100 using Tapatalk
Old 03-13-2011, 09:30 AM
  #27
sringer's Avatar
Yes...they say 30...but with 30 you run the risk of cracking the lubelockers and breaking the hardware.
Quick Reply: ARB diff covers
