Anyone remove Soft Top completely instead of just down?
I was looking at the Quick Disconnects available for JK softops. It seems the purpose is so you can quickly remove the entire top and frame instead of just folding it down ...
How many of you guys remove the entire top instead of just folding it down? I'm sure it definitely looks better and add more room in the back by removing it completely.
How heavy is it ??? How much longer does it take to remove and install ???
For folks that have the quick disconnects ... which brand is the best ???
Thanks ...
Thanks ...
Sponsoring Vendor
Off Road Evolution Rep
I have mine completely off right now. It's not hard to do at all just four torx and it's done. It's in no way heavy, I make sure that the arms are strapped together before I remove it to keep it from trying to open up. Taking off the mounting brackets requires unzipping the roll bar padding down by the base of the seatbelts and pulling up enough to get to the two torx on each side... I'd say go for it!
Hello,
I have removed mine a couple of times. Usually it's just folded down but if I know we have a stretch of decent weather I'll remove it for a few days.
It's actually very easy to remove, it's very light, and it doesn't take much room to store it. I leave it folded up and just lay it on my work bench when I don't have it on the Jeep.
I asked aboot quick disconnects like two years ago and this was the suggestion:
http://www.quadratec.com/products/11033_002.htm
I still have never gotten around to ordering any myself but the member who suggested them seemed to like them.
Beel
Beel
Thanks ...
Thanks ...
Thanks guys ... if it EVER warms up again in Georgia .... I'll give it a try taking i all the way off ... as long as weatherman says it's OK ....
You will find out quickly what you like. Dont waste money on quick disconnects. It takes zero time to take them off with a torx. I like it with no option to have the top on sometimes, it adds adventure. Sometimes I need to have an option and want to be able to be warm. You'll find your rhythm.
-Ram
-Ram
I used to take mine off completely in the summer. I lived in an apartment with a garage and was close enough to work that I could walk in it was going to pour. It doesn't take too long to put it back on once it's been taken off. It doesn't seem to really weight that much either.
Since I bought a house and don't have a garage now, I think I'll be reclining rather then removing this summer. But I think the quick disconnects would be a great item to have it you plan to remove completely.
